front end shimmy on T??
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Official RnS Addict digger's Avatar
    Jun 2009
    near ipswich
    3,404
    2784
    digger is offline
    I have had the problem before but not as bad..and was advised to put a little more caster angle and a panhard rod which i did and it went away fopr the most part except sometimes happenned when braking on very bumpy roads.
    sometimes my front end goes beserk....like really bad wheel wobble, they wheels start goiing leaft and right very quick and it shakes the whole car, it i dont fight with the wheel it usually stops but has gotten worse!
    I have about 7 degrees of caster and toe in is 1/16th, transit steering box all adjusted correctly, everything else seems to be as tight as it should with virtually no wear.
    any suggestions......
    Official RnS Addict rockhouse's Avatar
    Dec 2010
    clacton-on-sea
    996
    54
    rockhouse is offline
    wheels balanced ok
    tyre pressures ok
    dampers working ok
    23,888
    The shimmy is caused by the wheel setting up a gyroscope effect on one wheel and then being transmitted through the beam to the other side. I've a 30s suspension book that mentions it being a problem !
    Little bits of wear anywhere is the first thing to check , which you've already been through.
    More toe in will help to keep the car pulling straight and stop the shimmying. Take it up in 1/16 increments to 3/16ths total
    Too much caster can also cause shimmy as well as too little so worth a try knocking it back as well .
    Too high a spring rate can also cause the tyre to launch from a lump and start gyrating
    Too high tyre pressures ( especially coupled with too high spring rate ) will also start a wobble.
    EDIT . As it was OK before what changes have you made recently ? Taller tyres, raised or lowered either end, more weight added ?
    Herts. and ahead of Larry :)
    2,638
    34
    chevy2 is offline
    Maybe try fitting a steering damper to the steering cross tube,?
    They usually calm it down a fair bit,
    VW van ones are pretty cheap.
    Jun 2009
    near ipswich
    3,404
    2784
    digger is offline
    will check all above theorys this week, thinking about it one of the tyres looks a little down, will double check bearings and joints.... redo caster and toe in a little more.... hopefully cure it.
    if none of that works will look at a damper.
    Thanks
    Official RnS Addict Gavin's Avatar
    Solihull, Birmingham
    615
    515
    Gavin is offline
    Got the T-shirt on this one!
    Here is my thread from a couple of years ago...
    Beam axle steering problem - NSRA Forum
    If you are happy that everything is as it should be with the front end then the damper should do the trick.
    1,317
    Neil G is offline
    It is worth checking the tyres out,they might look ok but check the inside wall.Sometimes they ripple.
    Official RnS Addict old pizz yella's Avatar
    Aug 2009
    Hyde Cheshire
    1,122
    68
    old pizz yella is offline
    Only a little one but when was the last time
    you greased the king pins and all the steering joints they maybe
    tight but will wobble if dry , and are you front brakes discs or drum ?
    race it cruise it just use it and abuse it
    nscc 8
    having fun is usual
    Jun 2009
    near ipswich
    3,404
    2784
    digger is offline
    update...
    checked wheel bearing..ok
    regreased kingpins..till fresh grease came out.
    checked tie rod sperical ends...found a little wear in both.. replaced with new.
    checked drag link...ok
    kingpin angle is 6 degrees, will leave as is till rest done.
    going to have front end tracked and tyres took off and rebalanced, and then tracking set.
    hopefully will be sorted... and mot tommoro too!
    1,317
    Neil G is offline
    How'd it all go?
    Did it pass,the suspense is killin me
  1. Front wheel Shimmy
    Last Post: 01-08-2010, 00:41
  2. E04a front end and a 7y bumper
    By 1stpop in forum Stuff - WANTED
    Last Post: 20-07-2009, 14:54
  3. front end
    By Nobler in forum Stuff - FOR SALE
    Last Post: 06-07-2009, 18:04
  4. Corvair front end £75
    By Keith in forum Stuff - FOR SALE
    Last Post: 14-05-2009, 11:57
  5. Mustang II front end Q
    By J1MMY in forum Tech Discussion
    Last Post: 02-05-2009, 13:12
