fuel line hose
Results 1 to 10 of 11
Thread: fuel line hose
    on the low down elevensies's Avatar
    Aug 2013
    Lincolnshire
    473
    39
    elevensies is offline
    fuel line hose
    im about to take out my fuel line (10mm copper) and replace it with something bigger, and everything is pointing me towards Aeroquip an8 (1/2' internal) but its bloody expensive for 6 mts.
    In not trying to be cheap its just the cost is so far off normal rubber fuel line. so
    does anyone have any pros n cons for going down the normal rubber hose route or should i bite the bullet and go aeroquip!
    im using push on an8 fittings not the clamp on
    one day i wil wake up and i'll be dead!
    Sep 2014
    The north
    1,350
    1314
    nuggets is offline
    I would have said AN-6, AN-8 is bloody massive!
    Line wise, clamp on would be better but if push on just make sure you're under the pressure rating and its all good. I'm using push on for 100psi but I'm barely running 5 right now.....and I'll only be running 37 when I go EFI so I've got no issues
    Gym Junkie chrisvs's Avatar
    Jan 2011
    Hitchin
    6,213
    125
    chrisvs is offline
    Can you not use a suitable hard line and just do each end in Aeroquip, my advice would be to speak to Guy "bigyellataxi" on here as he should be able to sort you out, these are his details:
    A1 Hydraulics
    92 Cannock Street
    Leicester
    LE4 9HR
    Give this number a ring 01162761131 and ask for Guy it is where he works
    Paradise is full of idiots who believe it exists - Georges Wolinski
    I Think Therefore I Am - René Descartes
    www.nothingbeingadvertisedhere.com
    Aug 2013
    Lincolnshire
    473
    39
    thanks guys, i have just got a billet fuel pump 175gph, thats going on, and i dont want a hard line, i really want hose, an8 is 1/2 id 21mm od so yeah its a biggy
    will give Guy a call
    Aug 2013
    Lincolnshire
    473
    39
    Got sorted managed to pick up aeroquip equivalent for half the price, the man at the hydraulic shop did a comparison and said its the same only his was made in Germany.
    It's bloody big your right nuggets. I think I'm gona have fun routing it.
    My next questions gona be wiring the pump lol
    May 2011
    Hertfordshire
    2,499
    7
    Adam Sayers is offline
    -8 was the right choice as you have room to grow. I'm using -12!! If your running a return it has to be at minimum the same or bigger than the feed line.
    Wiring the fuel pump. If the battery is in the rear put a relay back there and use it to switch to a full 12v off the battery direct.
    1955-56-57 Chevy new and used parts always available from www.randrhotrodimports.co.uk who I'm proud to have sponsor my '57 Chevy race car. 9.3 @ 155.8 mph / 0-60 = 1.47 seconds! Street legal :-)
    Aug 2013
    Lincolnshire
    473
    39
    thanks adam
    yeah battery is in the back, i was going to wire the pump via a relay, off the ignition supply, and i was thinking of a separate pump switch on the dash, so i can isolate the pump while ignition is on.
    i do try make like complicated lol
    Jan 2011
    Hitchin
    6,213
    125
    chrisvs is offline
    Quote Originally Posted by elevensies View Post
    thanks adam
    You could also wire it up via the oil pressure switch so in the event of an accident/severed fuel line the pump will stop pumping fuel
    Sep 2011
    Kings Lynn
    2,864
    332
    brading is offline
    I would put a Inertia switch between the relay and the pump so it cuts of in the event of a acciident
    Aug 2013
    Lincolnshire
    473
    39
    Iv got a oil pressure switch kicking about, only single connector though????
    Inertia switch...I wonder how that would work when I lift the front wheels on launch lol
    Ideally I should get someone to wire it, I'm no good with electrics!
    1. Return fuel line?
      By chaley in forum Tech Discussion
      Last Post: 20-06-2012, 21:42
    2. copper fuel line?
      By Taff in forum On Topic
      Last Post: 11-04-2012, 12:16
    3. Holley Fuel Line kit- Brand New
      By Richd-X in forum Stuff - FOR SALE
      Last Post: 14-05-2011, 17:43
    4. fuel line diameter
      By harris66 in forum Tech Discussion
      Last Post: 18-03-2011, 15:44
    5. Fuel Line
      By Coppertop in forum Tech Discussion
      Last Post: 12-01-2011, 20:16
