Fuel pressure?
Results 1 to 10 of 39
Thread: Fuel pressure?
    Jul 2012
    isle of man
    247
    8
    ganzaigeorge is offline
    Fuel pressure?
    hi got a new Edelbrock performer 600 carb on an Offenhauser manifold,sitting on top of a 302 small block,fed by Holley electric fuel pump.What should a reasonable fuel pressure be?
    9,147
    1772
    blackpopracing is offline
    I believe it should be about 3psi at the carb? will probably need regulating down.
    up north
    1,987
    35kid is offline
    edelbrock performer 600 should be no more than 6psi at idle
    Jul 2012
    isle of man
    247
    8
    Thanks for that.Anyone have any more suggestions?I did once hear that pressure should nt be more than 6 psi? the reason I need to know is that at full throttle motor is missing,like a plugs breaking down,but not quite like that,its hard to explain....feels like a fuel problem,as if carb is like flooding?Can this happen if pressure is too high?It starts/ticks over nicely and at low revs runs great,but floor it and it misses................................cleaned pump out and it has new plugs,Mallory dizzy electronic and Accel coil.......any ideas?
    Feb 2010
    london
    458
    zephyrc is offline
    What holley pump,, red blue or black..fuel pressure should not be over 6psi,, prefer 5psi... Red pump doesn't need a regulator,, blue and black both need regulators,,holley 803 reg works well...
    Feb 2010
    london
    458
    zephyrc is offline
    Is problem as you hit the throttle or under sustained throttle
    Jul 2012
    isle of man
    247
    8
    I think its a blue pump and I think that problem is at sustained throttle in that it picks up instantly but keeping throttle pedal down it starts to "miss".If you drive as per normal traffic,sedately there dos nt seem to be a problem. Im draggin at easter so need to sort it out.
    Feb 2010
    london
    458
    zephyrc is offline
    If its the blue pump are you using the regulator with it..
    May 2011
    Hertfordshire
    2,499
    7
    Adam Sayers is offline
    6 but an Edelbrock can take up to 7 where a Holley likes 5-1/2 to 6.
    Quick tip. If your using a liquid filled fuel pressure gauge have it cold or use a non liquid one to set. In higher temps the gauge can read 7 when it's actually 2 or 3 due to the liquid in the gauge giving a false reason due to ambient temps.
    1955-56-57 Chevy new and used parts always available from www.randrhotrodimports.co.uk who I'm proud to have sponsor my '57 Chevy race car. 9.3 @ 155.8 mph / 0-60 = 1.47 seconds! Street legal :-)
    Jul 2012
    isle of man
    247
    8
    Unfortunately I don t have a regulator fitted,so Ill order one now and then see what happens............thanks for replies everyone
    1. Fuel pressure gauge
      Last Post: 06-08-2010, 21:40
    2. two petrol pumps and two fuel pressure regulators
      By ACEBOPPER in forum Tech Discussion
      Last Post: 07-06-2010, 14:38
    3. 1970's Stewart Warner fuel pressure gauge
      By Blue in forum Stuff - FOR SALE
      Last Post: 18-12-2009, 17:18
    4. Fuel pressure regulator
      Last Post: 23-10-2009, 16:59
    5. Fuel pressure/mixture adjustment?
      Last Post: 29-04-2009, 11:44
