Fuel pressure/mixture adjustment?
Results 1 to 10 of 19
    6,225
    1037
    English Impala is offline
    Just fired up the Chevy after a two week hibernation & its running as rich as it ever has! Black smoke, stinking of petrol, sluggish, the car's just the same... .
    Fuel pressure gauge shows 8 psi on tickover. Carb is an Edlebrock 600 4-barrel.
    The carb is off Andy (58 Delray's) 58 which has a 350, so I guess it might want the mixture tweaking for my 305? Fuel pressure, is 8 too high? I asked a similar question a while ago on the NSRA but can't find the bloody thing!
    Regarding setting the mixture, how? Many moons ago I had a special clear spark plug & you set the mixture until the right colour spark could be seen in the plug. I no longer have that & it wouldn't fit anyway! So, whats the best rule-of-thumb/basic set up for an Edlebrock as they are different to the Holley that I used to use?
    Herts. and ahead of Larry :)
    2,616
    34
    chevy2 is offline
    i'm guessing 8psi is too high,
    try starting on 5-6psi,
    to get the mixture right you'll need to get the motor up to operating temp,
    only then can you set the mixtures correctly,
    start off with the 2 mixture screws wound out about 2 turns each,
    once the motors fully warm, gradually wind the screws in 1 at a time to lean it out,
    once the idle drops off wind each screw out 1/4 of a turn,
    you should be fairly close.
    or use a vacuum guage using direct vacuum from the base of the carb,
    adjust the 2 mixture screws trying to get the highest reading at idle.
    6,225
    1037
    Thanks, just tried to adjust the pressure regulator & my metric allen keys don't fit! I'll buy an imperial set & try what you've said.
    23,350
    Yup, agreed. I wouldn't be looking at more than 5 -6 psi as well otherwise it can start pushing the floats up and dripping fuel in .
    Don't forget to recheck your float levels and you have got a filter inline i take it ? Dry tank can soon loosen particles when fuels added and stick the floats up.
    London Heathrowish!
    7,721
    46
    Plumpcars is offline
    Be wary of your pressure gauge when it's hot as well. On many of them the pressure on the gauge drops when the engine bay warms up. Checked mine the other day and it shows 1 !
    Rest in Peace
    Earl Shilton
    4,385
    1117
    SG57 is offline
    Quote Originally Posted by Plumpcars View Post
    I bet it ran OK Steve, a lot of old carbs used to run at 1lb. If you don't have new needles and seats 4lb would be a good start.
    If some's good, more's better and too much is just enough
    London Heathrowish!
    7,721
    46
    Runs fine Roger but I know that some of these gauges are known to be inaccurate when warm. I do think that people overestimate how much fuel pressure they actually need to run fine on a street car though.
    Anorak
    Wirral
    35
    19
    Gary Mc is offline
    OK I am guessing here as I don't know what type of gauge you have.
    But IF
    It is a liquid filled one, moon or similar and the reading goes wobbly on you, before you start swapping pumps etc there is a rubber plug on the side. It is a kind of blanking grommit. Pull it out and a bit of the magic juice that is in there will ooze out and all will be good.
    If your gauge is not that type then ignore what i said.
    G
    6,225
    1037
    Pressure wound down to 4 psi, new filter fitted, sorted! Thankyou.
    Leicester
    5,696
    594
    bigyellataxi is offline
    Cool, can I carry on washing up now???
    Do you want that blokes number re the bonnet???
    Quote Originally Posted by English Impala View Post
    Fueled by Jim and Luckies.
    1. Under pressure
      By Britdragster in forum Tech Discussion
      Last Post: 19-03-2010, 20:15
    2. 1970's Stewart Warner fuel pressure gauge
      By Blue in forum Stuff - FOR SALE
      Last Post: 18-12-2009, 17:18
    3. Edelbrock carb adjustment
      Last Post: 23-10-2009, 17:25
    4. Fuel pressure regulator
      Last Post: 23-10-2009, 16:59
    5. oil pressure lose or to much crankcase pressure
      By chris-461 in forum Tech Discussion
      Last Post: 12-08-2009, 14:32
