Fuel Pump Pressure please
Results 1 to 7 of 7
    Aug 2009
    South Cheshire
    1,425
    50
    RockabillyBilly is offline
    Hello again. I'm thinking of converting from a original, mechanical fuel pump to an electrical one. Could one (or all) of you clever lot tell me what pressure the pump needs to be please. I'll probably go for a pump mounted near the tank.
    The engine is a 2.6 Straight six with a standard Zenith carb and a three speed 'box.
    Thanks in advance.
    May 2010
    lichfield staffs
    4,451
    407
    streetfighter is offline
    I'm no expert, but i've usually used 4 psi on most things with carbs.
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Standard ticker pump off Morris Minor and similar. I have same engine, albeit minus two cylinders, and it feeds it fine. Mount on mini exhaust bobbins to quieten it down a bit.
    23,576
    It's really based on fuel bowl capacity and float volume vs needle plus overall BHP made. Webers need 3psi min, Holleys generally about 5 psi max. Morris Thousand is 1.5psi and MGB 2.5. I powered 110 bhp on a 2.5psi and it leaned out on top end but switching to 3 psi cured it. So looking at power output I'd be going with a 3 psi pump.
    Aug 2009
    South Cheshire
    1,425
    50
    Thanks all. Much appreciated as always.
    13,286
    mygasser is online now
    sounds ok except the holley recommendation kev. i've used facet red tops on holleys for years and they're 6.5 psi. never had an issue.
    23,576
    We can all only recommend on experience Neil I've found that over 5psi when ticking over for a long time ,say in traffic, they slowly start to overflow into the venturi . As for my mates Holley with an unregulated Jag SuU pump ( which turned out to be 9 psi ) that would tick over for about a minute and then start to belch black smoke
    1. fuel pump pressure??????
      By 63Wagon in forum Tech Discussion
      Last Post: 04-01-2013, 00:31
    2. 2L OHC - fuel pump advice please.
      By Russ D in forum Tech Discussion
      Last Post: 13-02-2012, 19:45
    3. tpi fuel pump wanted please
      By Crookes37ford in forum Stuff - WANTED
      Last Post: 24-04-2011, 21:14
    4. Lincoln 430 Electric fuel pump tips please??
      By mrbthebarber in forum Tech Discussion
      Last Post: 15-06-2010, 18:45
    5. Fuel pump advise please
      By 56 AUSTIN in forum On Topic
      Last Post: 07-06-2009, 19:49
