Fuel sender Q??
Likes Likes:  7
Results 1 to 10 of 20
Thread: Fuel sender Q??
    Rods 'n' Sods Junkie C10apache's Avatar
    Jun 2018
    Aberdeenshire
    164
    6
    C10apache is offline
    Fuel sender Q??
    Hi folks I was wondering if my fuel sender needs grounding??
    My sender has only one terminal post on it which I have attached the power wire from my loom,
    What would be the best way to ground it do you think??
    Regards Stuart
    Sent from my LYA-L09 using Tapatalk
    13,453
    the sender is metal and grounds to the tank. the tank is metal and grounds to it's brackets. the brackets are metal and ground to the chassis. the chassis 'is' ground so........
    sort of like your ankle bone connects to your shin bone etc........
  4. Likeskapri liked this post
  5. #3
    Jun 2018
    Aberdeenshire
    164
    6
    Lol so no ground required
    Regards Stuart
  6. Remove Advertisements
  7. #4
    May 2016
    S E London
    948
    22
    timbo56 is offline
    If you want to be doubly sure you could run an earth wire from one of the five fixing bolts to a good earth point on the chassis.
  8. Likesmygasser, stu460 liked this post
  9. #5
    Jun 2018
    Aberdeenshire
    164
    6
    Quote Originally Posted by timbo56 View Post
    Cheers yeah I did think of doing that I'll put one on just incase
    Regards
  10. #6
    Rods 'n' Sods Junkie shovelheadrob's Avatar
    Aug 2012
    Cambs
    381
    shovelheadrob is offline
    Or just check for continuity with a multi meter, between the body of the sender & the chassis? In theory if there's a rubber gasket between the sender & the tank, then rubber protection between the tank & the mounting straps or between the tank & the body, it could fail to earth that way.
  11. Likeskapri liked this post
  12. #7
    Jun 2015
    Afghanistan
    329
    stevieturbo is offline
    Quote Originally Posted by C10apache View Post
    Regards Stuart
    No, he's saying he assumes the tank ( and indirectly the sender ) should be grounded already.
    But absolutely yes the sender needs grounded.
  13. #8
    13,453
    Quote Originally Posted by stevieturbo View Post
    it might, it might not. it is a fair assumption with metal parts bolted together. agreed, it's cheap insurance at the stage of the build he's at though.
  14. #9
    13,453
    Quote Originally Posted by shovelheadrob View Post
    a multi meter check would confirm it but a gasket wouldn't stop the nuts and washers touching the sender so earthing it to the tank. if there are rubber/fibre 'seals' around the studs then an earth wire on any of the studs still wouldn't earth it either. so yes the multi meter check is the best first course of action. and yes an earth wire would be cheap insurance at this stage of the build.
  15. #10
    Jun 2015
    Afghanistan
    329
    Except as shovel said....it should also be an assumption it is not 100% directly all bolted to metal and there is some means of cushion/isolation from the chassis. Whether via straps, rubber, whatever.
    So I would assume the tank is not a reliable earth, unless it has been given a reliable earth. And I guess he's asking because his gauge didnt work ?
    1. Replies: 2
      Last Post: 18-05-2014, 18:00
    2. Fuel sender/fuea guage reading's
      By roofer in forum Tech Discussion
      Last Post: 09-08-2009, 17:38
    3. fuel sender/slow starting
      Last Post: 09-06-2009, 18:16
    4. how to measure fuel tank for sender
      Last Post: 07-06-2009, 00:05
    5. 40's ford fuel sender unit
      By jack earls in forum Stuff - WANTED
      Last Post: 26-04-2009, 08:37
