Fuel starvation
Results 1 to 4 of 4
Thread: Fuel starvation
    is currently reloading. Taff's Avatar
    where you least expect it
    836
    742
    Taff is offline
    Fuel starvation
    the chevy is suffering from fuel starvation.
    I'm not using it at the moment, just up and down the drive manovering to work on it and stuff.
    It will start fine and run ok, if started regular (as in every other day)
    leave it more than a week and i need to prime the carb and fuel line with petrol to run the engine long enough to draw fuel from the tank. Either that or disconnect the pipe at the lift pump inlet and syphon the fuel to that pint. Both option are a pain in the arse when all you want to to is move the car to get at something. Everything is working, it's just that the fuel seems to have ran back to the tank and the pump isn't man enough to draw fuel past the low point in the main fuel pipe
    The fuel pipe from the tank is pretty long and has a low point due to the path it has to take.
    any suggestions as to how to prevent this? check valve put somewhere in the line? at the fuel tank end?
    A bullet might have your name on it, hand grenades are addressed "to whom it may concern......."
    You can never have too much red wine, too many books or too much ammunition.
    Kent
    424
    8
    Morecubes is offline
    Re: Fuel starvation
    Diesel Mercs suffer from the same problem when the fuel lines get old & hard - they sell an electrical solenoid that you fit close to the (in your case carb) that is ignition fed so as soon as you turn off the engine the "drain" route to the tank is shut off. I think they're about £20 & could probably dig up a part number if you're interested.
    Chester
    131
    blackjack is offline
    Re: Fuel starvation
    I now replace mechanical fuel pumps with SU electric pumps to avoid this; just turn on the ignition, listen to the ticking and wait until it stops then fire it up. Saves the starter motor and the battery.
    836
    742
    Taff is offline
    Re: Fuel starvation
    Quote Originally Posted by blackjack View Post
    just been out and fannied around with it, cleaned and relocated the tank breather just in case. no change
    anyone know what size/flow rate elec fuel pump to run a 235ci motor?
    1. Re: Fuel starvation
      By Morecubes in forum Tech Discussion
      Last Post: 27-04-2010, 08:19
    2. Fuel prices
      By goldigger in forum Chat
      Last Post: 02-04-2010, 19:37
    3. sit up and beg fuel tank
      By yellapop in forum Tech Discussion
      Last Post: 18-12-2009, 20:11
    4. Pop fuel tank
      By Stroprock in forum Stuff - WANTED
      Last Post: 26-11-2009, 22:13
    5. pop fuel tanl
      By sd156 in forum Tech Discussion
      Last Post: 23-06-2009, 10:01
