Fuel supply diagnosis
Results 1 to 10 of 12
    Official RnS Addict ChopperHarris's Avatar
    Oct 2011
    SW France
    1,194
    21
    ChopperHarris is online now
    1962 Simca
    Consider it as a Ford of the same age.
    Wouldnt start after a 3 month body refurb.
    Traced to a dead condensor.
    Now runs on tickover fine but dies after 300m normal driving.
    Carb dismantled, cleaned and changed as a last resort
    Bubbles in inline petrol filter, bypassed, same result
    Removed mechanical pump tonight and can blow through....pump "arm" by hand with finger over outlet and pressure is still there after 30 seconds so assume diaphragm ok?
    Tank half full and just put in another 20 litres, all is fresh.
    When pipe is removed from carb and engine cranked, first two pumps are strong then a dribble (ooh err)
    So its a supply problem, all unions tight, tank vent clear, tank emptied twice(drained), and no more rust.
    Any opinions ideas please
    Stroker Kustom Jim's Avatar
    Bath
    4,726
    2606
    Kustom Jim is online now
    Lovely car!
    Dunno about issue but hazard pump may be untoward. If it's ancient it's just an investment servicing anyhoo.
    What about, pull the plugs and spin the bleeder over with pump installed and a visible fuel line in to bucket to see if it keeps on squirting!?
    Feb 2013
    uranus
    2,024
    ivanhoew is offline
    breather blocked in tank cap ?
    Bicester scramble ,Medusa enjoyed the trip.https://www.youtube.com/watch?v=Q-7I7-nA19U
    Oct 2011
    SW France
    1,194
    21
    Thanks, tried it without cap
    Oct 2011
    SW France
    1,194
    21
    Quote Originally Posted by Kustom Jim View Post
    Lovely car!
    Thanks, the filter is visible and the squirting drops after the first two pulses
    I agree about the service item but unlike a Ford parts are scarce, especially here in boondock France...
    12,496
    facet or similar leccy pump?
    did you blow back down the fuel pipe from the pump to the tank in case there's muck in there somewhere?
    22,817
    Any rubber lines at all ? If they are not marked as suitable for unleaded bin them . I've had them breakdown inside and create blockages that ebbed and flowed ith pressure and mileage.
    Mar 2010
    Stevenage
    536
    268
    rovertenrod is offline
    Is there a strainer on the pick up pipe? I’ve had these block up and after shopping the crap drops off. Also had similar from plastic and material in the tank. Not had the rubber issue on fuel lines yet, had it with brake lines a few times though!
    Oct 2011
    SW France
    1,194
    21
    Its mechanical pump.
    Yes blown back down..not sure about strainer, the pick up pipe enters the top of the tank.
    The rubber pipes at engine end, carb to filter, filter to pump and pump to solid, are new and clean.
    Could be bubbles entering the filter be a failed diaphragm in pump (but it holds pressure as in OP)?
    Feb 2013
    uranus
    2,024
    ivanhoew is offline
    is it feasble to stick the pipe to the tank in a petrol can , just to completely rule out tank related probs?
  1. Help with fault diagnosis. I think its the trans!
    By pieman in forum Tech Discussion
    Last Post: 29-08-2011, 16:19
  2. Antique Auto Supply
    By bigdavy in forum On Topic
    Last Post: 28-09-2010, 20:24
  3. White Haired Shrunken Heads in stock - limited supply
    By Manzo in forum Stuff - FOR SALE
    Last Post: 06-03-2010, 23:55
