Fuel Tank plumbing help needed - Jaz fuel cell confusion!
Results 1 to 4 of 4
    Rods 'n' Sods Junkie matt100e's Avatar
    Jul 2009
    Stroud
    267
    17
    matt100e is offline
    Hi Guys,
    I've got a Jaz fuel cell for the gasser, and been getting confused as to how to plumb it.
    Its got one outlet and one vent fitting with tip over valve but has no return fitting.
    jaz fuel cell
    Do you need to run a return pipe to the tank?
    I've got a RMD fuel pump rated at 6-7.5 psi and a regulator to bring the pressure down for the carb which is a holley 600cfm 4 barrel.
    Would the back pressure from teh regulator not put strain on the pump?
    Any ideas and help is appreciated!
    Matt
    Official RnS Addict harris66's Avatar
    Jul 2009
    solihull
    2,385
    79
    harris66 is offline
    no return needed generally on a carbed engine, and the fuel pump should sense the pressure and adjust accordinly. so basically feed from tank to pump, pump to regulator, reg to carb, oh and a decent filter in there aswell!
    i want cubic inches! lots of em!!
    Jul 2009
    Stroud
    267
    17
    matt100e is offline
    Quote Originally Posted by harris66 View Post
    Brilliant thanks for that! makes life nice an easy
    Official RnS Addict LUCKY777's Avatar
    west yorks
    2,765
    127
    LUCKY777 is offline
    On the other hand........ I used a BG400 pump with a regulator built in to the pump , with a return line back to the tank. If you need to run a return line , empty the baffle foam from the tank , drill a suitable hole for a dash 6 or 8 bulkhead fitting , clean the tank out , and you can use the new fitting for the return . You can always blank it off when /if not used.(dont forget to refit the foam)
    Cheers Wayne
    visit us at www.luckydevil777dragracing.com "life isnt an audition"
    1. Street car fuel cell
      By Plumpcars in forum Tech Discussion
      Last Post: 01-09-2010, 11:14
    2. Fuel cell
      By sowat in forum Stuff - FOR SALE
      Last Post: 14-08-2010, 10:06
    3. Jaz Fuel Cell or similar
      By Pepsi Max in forum Stuff - WANTED
      Last Post: 26-05-2010, 23:47
    4. 16 gallon fuel cell
      By nik347 in forum Stuff - WANTED
      Last Post: 23-01-2010, 03:03
    5. lube help needed
      By sqweaka in forum Chat
      Last Post: 06-05-2009, 16:54
