Garage spray booth.
Results 1 to 9 of 9
    Jun 2011
    bradford west yorkshire
    381
    481
    splitty66 is offline
    Garage spray booth.
    In the next couple of months I will be starting to paint my car hopefully, what’s the best way of making a extraction system, I’m thinking of making a door with filters and a couple of car rad fans to extract the paint fumes, has any one done this and was it successful, the garage will be lined out in plastic sheet on the walls and ceiling , i will also put in an air inlet , all suggestions accepted, cheers ...
    Feb 2010
    Essex
    772
    dodgeman is offline
    Don't do what a mate of mine did. He put an extractor fan in the booth with it extracting out through the wall, and bought himself an air fed mask, so he was all good to go. Not long into his first spray job he felt worse than when he hadn't bothered with the extractor or the mask. He had to give up. When we had a look at his installation he had the extractor outlet right next to his compressor, so the fumes were sucked out through the wall, into the compressor, and straight down the airline to his mask....
    We thought it was hilarious at the time, (and since tbh) but if he had been spraying 2-pack instead of cellulose it would have probably killed him.
    6,207
    1037
    English Impala is offline
    Mark (Blackpopracing) used a 12 volt car radiator fan in his garage. I am sure it's shown in his build thread in Garage Scene.
    nowhere
    6,827
    2363
    nobody is offline
    Quote Originally Posted by English Impala View Post
    ask mark what his neighbours thought about his painting.im pretty sure they had overspray in their kitchen,lol.
    i spray here sometimes in my small garage.only generally primers and underseals.i have a wall mounted extract fan,that vents out at low level.i usually wet the floor when i paint,and just generally clean the walls and ceiling beforhand,to get rid of dust/webs etc.
    my compressor is mounted in my workshop.
    one tip.turn the extractor on once you are inside the garage,and turn it off befor you open the door.mine is super powerfull,and will pull dirt in from outside if you open up with it running.
    paint stinks.2k is worse.i only spray at night or if its raining. i have sprayed in the afternoon(a long time back) ,in the summer.apparently you can smell it half way up the road.
    6,207
    1037
    Yep, rain damps down the smell no end. I do my painting during the day when most are at work. It definitely smells and travels. I've got to repaint the Ranchero's bonnet after a gtinding disc exploded & damaged it, I'll do that early in the morning.
    Welding Guru
    Apr 2012
    Runcorn Cheshire uk
    555
    506
    30
    weldtech is offline
    Make sure any fans suit the size of any ducting so you get the air movement you need.
    The key to air extraction is what is known as "air change"
    This is based on a calculation in which the amount of solvent or paint concentration requires a specific volume of "clean" air to replace the contaminated air.
    Mind sound a bit sciencey but you want to make sure the air is of such a quality that your mask is good enough so you dont solely rely on a mask to protect you and make sure an environment that could cause an explosion from sparks or static from any fans doesnt develop.
    ( more air change = safer atmosphere)
    8,879
    1759
    blackpopracing is offline
    Neighbours at old flat were ok with paint, neighbour complained about the thinners cleaning the gun afterwards.
    I used a BMW 15" rad fan on my old garage, now I have a full 240V 450mm extractor on a speed controller. Make sure air inlet has a fine screen over it (open window with fine net curtain sealed over it will do). You ideally need the entire contents of the air volume of the garage exchanged every 60 seconds.
    Spraying in the rain is not so good as your compressor is compressing damp air which ultimately can get into the paint (even with a water trap), but having a garden hose set to a fine spray over the outlet of your extractor will work wonders.
    Painting later in the evening works best, neighbours will be indoors with windows shut so its much less of an issue.
    nowhere
    6,827
    2363
    nobody is offline
    spraying in the rain is fine if youre compressor runs industrial driers in the system.i bet is fine for every other person who hasnt got them as well.
    ****ing hell,if everyone waited for dry days to paint,nothing would ever get done.
    is that why it took you 30 years to do what most others do in one or two
    8,879
    1759
    Have you got a problem with me Wayne?
