gearbox or clutch problem ????
Results 1 to 4 of 4
    Rods 'n' Sods Junkie andy's Avatar
    edinburgh scotland
    410
    74
    andy is offline
    put a new clutch on a lt77 5speed box
    replaced flywheel spigot bush
    everything apart from release bearing carrier
    and fork & when sitting ticking over its
    rattling its tits off press clutch pedal & it dissapears
    same problem before changing clutch etc
    will the problem be the bearing carrier worn
    or the small bits of metal that locate the bearing carrier to the fork
    or is the gearbox us
    its a new release bearing pressed on to the carrier
    wolverhampton
    1,392
    redvictor is offline
    Re: gearbox or clutch problem ????
    It's usually wear in the front gears themselves. If revving it up slightly makes it go away don't worry about it. Pressing the clutch stop the input shaft rotating.
    Europe's quickest and fastest street legal car. 4.09 @ 191 - 6.27 @ 237mph so far...
    IVA legal too!
    Penn Autos/Andy Frost race transmissions.
    www.redvictor1racing.co.uk
    Feb 2010
    london
    458
    zephyrc is offline
    as andy said its the gearbox not the clutch.. gearbox is always turning even in neutral and only stops turning when you press the clutch.. could be either first motion shaft bearing or the gears
    edinburgh scotland
    410
    74
    andy is offline
    thanks guys
  1. Charging problem
    Last Post: 14-05-2010, 16:10
  2. 85 z28 fuel problem
    By tuckers in forum Tech Discussion
    Last Post: 03-05-2010, 12:07
  3. V6 oil pressure problem
    By Tiddytime in forum Tech Discussion
    Last Post: 22-11-2009, 20:33
  4. Browser problem
    By kapri in forum Chat
    Last Post: 21-10-2009, 23:22
  5. c4 gear box problem
    By old pizz yella in forum Tech Discussion
    Last Post: 16-08-2009, 15:57
