Gm turbo 350 trans leak
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Official RnS Addict mikeyboy's Avatar
    San Diego.Calif USA
    2,422
    209
    mikeyboy is offline
    pulled the pan twice to try to cure the leak out of the gasket rail. Put on a new thicker gasket METICULOUSLY installed and still it leaks. I did not put sealer on gasket as I understand you are not supposed to. When the fluid drains down into the pan on turning off the engine it is going to be above the pan gasket surface right? I dont even know if I have the correct dipstick as it was already in the truck when I bought it.Maybe its over full.....any ideas as to why it keeps leaking??
    There's no replacement for displacement.
    Flange Dealer Paul G's Avatar
    Derby , UK
    642
    57
    Paul G is offline
    Re: Gm turbo 350 trans leak
    If it is a pressed steel pan it may have "mole hilled" around the bolt holes (dented upwards) try hammering them flat as they will prevent the pan pulling up to the rail properley.
    Yes , fluid will be well above the gasket.
    wolverhampton
    1,392
    redvictor is offline
    Is it definetely the pan gasket? Like Paul says a cheap steel pan will indent the bolt holes after a few on/off's. Where is it leaking? front,side,back?
    Europe's quickest and fastest street legal car. 4.09 @ 191 - 6.27 @ 237mph so far...
    IVA legal too!
    Penn Autos/Andy Frost race transmissions.
    www.redvictor1racing.co.uk
    Official RnS Addict 29stude's Avatar
    Nov 2009
    chesterfield/derbyshire/uk
    746
    567
    29stude is offline
    Just a thought, following redvictors post, have you checked the selector shaft seal? had one leak on my th350 a while ago, oil ran down, soaking the pan and made it look like a leaking gasket.
    San Diego.Calif USA
    2,422
    209
    mikeyboy is offline
    Its a new pan one of those chrome ones with the drain plug. I trash canned the old steel one as it was leaking out of that too. Could be the selector shaft seal.I'll replace that and see what happens. It looks like its leaking out the front right corner as thats where the puddle on the garage floor is.
    wolverhampton
    1,392
    If it's right hand looking from the front it could be the seal. You'll need to get the pan off as the selector shaft has to be removed to change the seal. Put loctite on the outside of the seal to stop the oil ingressing past the case.
    Sometimes i've had to put some sealer under the bolt heads to stop silly leaks off the pan gasket. Only a thin bead mind.
    IVA legal too!
    Official RnS Addict cabby's Avatar
    Surrey
    838
    34
    cabby is offline
    Could it not be the dipstick O ring if its the right hand front corner?
    S.E London
    5,697
    510
    vince-305 is offline
    Quote Originally Posted by cabby View Post
    Depends if your in the car or looking at the car from the front Tony but i too was going to say dipstck tube, kick down cable or trans pipes on that side
    I replaced my sump gasket and done the holes with a ball pein hammer and it tuned out to be kickdown hole ( i dont have cable fitted)
    If its on the other side then youve got as Andy has said selector shaft or even speedo cable
    And if its none of those then it could be the rear seal running down the casing before it drips (or is my box to high)
    Bit'z 'N' Piece's
    San Diego.Calif USA
    2,422
    209
    mikeyboy is offline
    I've pulled those seals before without pulling the pan using one of these nifty tools. The leak is on the right side looking out from inside the car. I may just pull the motor and trans to do it as its very tight in there as its in a Model A with not much room to see anything from under the car.
    S.E London
    5,697
    510
    So the leak could be dipstick , kickdown , trans pipes , modulator ? (big round thing on the side) , or the vac unit at the rear then, as from memory there all down that side
    Good luck
    Bit'z 'N' Piece's
    1. SBC oil leak, possible rear crank seal?
      By Britdragster in forum Tech Discussion
      Last Post: 21-03-2010, 20:31
    2. help ..oil leak somewhere? 67 chrysler
      By jimo62 in forum Tech Discussion
      Last Post: 12-03-2010, 20:36
    3. 350 SBC Turbo VS 572
      By Countryboy in forum On Topic
      Last Post: 04-02-2010, 19:22
    4. turbo 350
      By stevie.t in forum Tech Discussion
      Last Post: 29-01-2010, 20:35
    5. Infer-red leak detector "SOLD"
      By Zody in forum Stuff - FOR SALE
      Last Post: 02-06-2009, 21:28
