Ha viva top wishbone bending under braking ?
Results 1 to 5 of 5
    Official RnS Addict 1stpop's Avatar
    isle of sheppey kent
    2,484
    48
    1stpop is offline
    Has anyone else come across this , it's a ha viva front with coil springs up the middle of top wish bone .
    Polly bushes top and bottom ,
    Go forwards and brake top wishbone looks like it's twisting as steering rack arm goes down and coil spring clonks top wishbone , go in reverse and it does it other way around ?
    Has anyone else noticed this , not got time to make new , so thinking as per ( my gasser ) Neil said , machine polly bushes down a bit and make new sleeves like original ha viva fronts as polly bushes don't sit in sleeves so about half the contact area as per original , then brace the wishbones themselves .
    Cheers dazza
    Mar 2010
    Stevenage
    565
    286
    rovertenrod is offline
    Correct me if I'm wrong, but if I remember correctly, there isn't room for a coil on a HA top arm? Back in '79 I fitted a new upper member and HB/HC top arms. That's what yours look like. Could this be the issue?
    Official RnS Addict scottie's Avatar
    Resin City
    4,058
    1401
    scottie is online now
    cant see the leaf spring in the first pic through the gap in the bottom arm, have you removed it ?
    if so i reckon this is the problem
    23,576
    Quote Originally Posted by scottie View Post
    Yup, I'd go with that idea as the leaf spring imposes loads front to rear and across lower arm. New coilover is fixed so the bottom loads are in a totally different place and are making the area, where the leaf spring adds additional strength to the arm , flex and twist ?
    2,484
    48
    1stpop is offline
    Sorry it has one leaf in it now , these are older pictures .
    On closer inspection ( day light )
    It's the pivot point on the lower wishbone moving , so it's either the bushes or the holes have elongated where the bar mounts through the cross member .
    1. ha viva lower wishbone
      By 4xmike in forum Stuff - WANTED
      Last Post: 04-01-2014, 20:57
    2. Vauxhall Viva front wishbone rubber bump stops ???
      By Tarmac Tanner in forum Stuff - WANTED
      Last Post: 29-09-2013, 15:06
    3. camaro top wishbone bushes
      By simon landlord in forum Stuff - WANTED
      Last Post: 14-07-2013, 23:35
    4. HA Viva lower wishbone pivots
      By Robbo149 in forum Stuff - WANTED
      Last Post: 05-06-2013, 19:37
    5. HA VIVA lower wishbone mount WANTED
      By street gasser in forum Stuff - WANTED
      Last Post: 30-07-2012, 17:11
