Having an rear axle shortend by someone ? Who would you use ???
Results 1 to 10 of 13
    Jul 2011
    zzzzzz
    188
    9
    TIB3300 is offline
    zzz
    Welding Guru
    Apr 2012
    Runcorn Cheshire uk
    622
    524
    30
    weldtech is online now
    I would recommend someone on here, but whovever you get to do it, ask them about how they plan to re weld the cut tubes. Weld quality is key to getting a good job done and uniform weld application is how the axle stays true without any excessive straightening.
    When i do mine i go over the top with accuracy and weld quality/post weld inspections. The weld set up is a single vee butt weld
    I do MPI (magnaflux) for any sub surface cracking in the parent metal following flush sanding and get my old mate to do 3 xray shots of it to provide a record of the weld and confirm the quality of the penetration bead on the inside of the tube.
    I only use tig for the welding as its a high dilution process for better penetration. During all welding passes (normally 3) i do dimension checks for alignment and balance each weld to counteract any distortion from previous passes. Never had to straighten 1 yet.
    Official RnS Addict D COUPE's Avatar
    WEST YORKSHIRE
    648
    33
    D COUPE is offline
    ITS NOT WHAT YOU DRIVE ITS HOW GOOD YOU LOOK IN IT
    Official RnS Addict zefa46's Avatar
    Westhoughton Bolton lancs
    1,440
    164
    zefa46 is offline
    Having mine done at Hausers he doesn't cut half shafts , buys new in from the states to size needed , does the case in a jig . costs more but safe
    Welding Guru
    Apr 2012
    Runcorn Cheshire uk
    622
    524
    30
    I agree, no cutting and welding of driveshafts for me either.
    The cutting and welding i mentioned related to the axle tube not half shafts.
    And i would ask the same welding questions of hauser too. A good outfit should have no issue answering those sort of technical questions to be fair
    Jun 2009
    Rayleigh Essex
    3,177
    288
    trevd is offline
    Steve large, large engineering in Kent did my 9" and it was a great job, I supplied custom 4 link brackets and new ends and he did the rest. all done in a jig and was spot on.
    Stroker Kustom Jim's Avatar
    Bath
    5,216
    2764
    Kustom Jim is offline
    Looks like the OP has done one.
    From what I've seen it is a real engineering feat to achieve so would use recommended as above.
    Had a new bespoke 9" from Hauser and one of the off the shelf Strange halfshafts was 1/2" too long
    John Sleath does em up north.
    kent
    2,961
    choppedblownpop is online now
    Mine Steve Large did after he had it powder coated
    Jun 2010
    yorkshire
    356
    9
    cougarv8 is offline
    If you have a proving bar with the dummy bearing set up its a cakewalk there is no voo doo in shortening an axle casing, We did mine in a cow shed in '92. Welding is important
    68roadrunner
    nowhere
    7,089
    2412
    nobody is offline
    think hes fooked off. any rod shop will narrow axles
