Help with Vauxhall Victor master cylinder......
Results 1 to 7 of 7
    I'm a newbie !
    Mar 2012
    Cambridge
    19
    Sputnik is offline
    Hi Folks,
    I'm rebuilding a brake master cylinder off a Victor ( F-Type 1960), got hold of the rebuild kit but don't have a workshop manual, yet.
    The pump aint pumping! There's pressure there but fresh fluid isn't flowing into the cylinder. The way is clear from the reservoir but it's just pumping air not refilling. Also the three holes in the piston are clear.
    This is how I've got the bits:
    I've tried the shim both ways but no dice. All seems to go together ok but have I got something wrong?
    Any ideas?
    Cheers,
    Jon
    Sep 2011
    Kings Lynn
    2,983
    380
    brading is offline
    Hi there
    I have got a set of factory manuals at home if you would like to PM me your email address I will scan the relevent pages and email them to you.
    Sep 2011
    Kings Lynn
    2,983
    380
    brading is offline
    I take you are using Dot 4 brake fluid and not silicon brake fluid. You also need 1/4 to 3/16th free pedal travel to make the the piston is returning fully home.
    I'm a newbie !
    Mar 2012
    Cambridge
    19
    Sputnik is offline
    Yes I'm using Dot 4 and bench testing so I have full stoke on the piston. It is returning fully home too.
    Cheers,
    Jon
    Sep 2011
    Kings Lynn
    2,983
    380
    brading is offline
    Hi Jon
    have you recieved my email yet. Sent it a little while ago.
    cheers Paul
    I'm a newbie !
    Mar 2012
    Cambridge
    19
    Sputnik is offline
    Got it! Thanks again!
    Sep 2011
    Kings Lynn
    2,983
    380
    brading is offline
    Hi jon any luck with the master cylinder. Just a thought are both ports clear in the bottom of the reservior.
    1. Victor Fe Brake Master Cylinder ?.
      By Mike Hunt in forum Stuff - WANTED
      Last Post: 05-07-2011, 12:52
    2. Replies: 8
      Last Post: 28-02-2011, 16:38
    3. Replies: 4
      Last Post: 28-11-2010, 21:23
    4. Help Ford Pop with Vauxhall front Wishbone problem
      By Gr8h8me in forum Tech Discussion
      Last Post: 12-06-2010, 20:29
    5. duel brake master cylinder with servo for tri 5
      By punk in forum Stuff - WANTED
      Last Post: 26-12-2009, 17:39
