Holley carb tuning
Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 65
    Rods 'n' Sods Junkie SpannerPete's Avatar
    Nov 2009
    Bedfordshire
    301
    19
    SpannerPete is offline
    Holley carb tuning
    Hi,
    I've got a 383 SBC with a holley 750cfm (0-3310S) and a single plane high rise manifold.
    It idles ok has loads of go when on the gas but at very light throttle is coughs/misses/judders (1400 rpm/ 30 mph just when you need it!).
    It has about 9" of vacuum at idle and a 5" power valve. Vacuum when the problem occurs is about 15", a little throttle and the vacuum drops to below 10" and the problem goes.
    I've tried upping the spring rate in the vacuum secondary and this didn't help but just gives a slight hesitation when I go on the gas.
    Not sure if it makes much difference but it's in a light car (fibreglass T) and has a lightweight flywheel.
    I'm getting to the pulling my hair out stage so any suggestions welcome.
    Thanks
    Pete
    London Heathrowish!
    7,723
    46
    Plumpcars is offline
    Have you got vacuum advance?
    Nov 2009
    Bedfordshire
    301
    19
    Quote Originally Posted by Plumpcars View Post
    Yes, forgot to mention that sorry.
    Herts
    4,620
    224
    WB54 is offline
    try adjusting the pump shot or use the next size up shooter.
    23,634
    What sort of cam in there to get only 9 " at idle ? Sound radical ? What's the quoted power band?
    Nov 2009
    Bedfordshire
    301
    19
    Will this effect it at steady throttle position which is where I have my problem? I'm still trying to understand all the different parts and what they all do.
    Not sure on the exact cam but it shouldn't be too radical. It should be good from idle to 6000, but I've only got a dyno sheet from 3000 to 6000
    South West Essex
    4,093
    14
    Roscobbc is offline
    Sounds as though you may have a 'transision' problem where the carb is going from off-idle (where it runs OK I presume) to main jet where I guess you have done a plug colour test at wide open throttle on a run? (to be sure its not main jetted too weak). This 'stumble' can be a really difficult thing to tune-out of the carb - typically you MAY need to change idle bleed jetting if it has removable jets or restrict/drill-out passages if a low-spec carb. It sounds typical of a 'stiff' cam/low vacumn scenario where the carb isn't pulling enough vacumn through the venturis to atomise the fuel just off-idle. With non-adjustable idle bleeds an old trick was to drill a couple of 1/8" holes in primary butterfly to allow enough air to flow off-idle.
    Nov 2009
    Bedfordshire
    301
    19
    Quote Originally Posted by Roscobbc View Post
    I've not done a WOT yet but it has been set up on the dyno so I assume that should be correct. I have read about the drilling tricks but am nervous about drilling a new carb. Is the 15" of vacuum at 1400rpm not enough?
    Thanks for all the replies
    23,634
    Antons T is running a 1500-6000 cam and pulls about 18" at idle . My Pinto had a 1000-6000 cam and was pulling 21 at idle . His used to read around 16 until we sorted the vacuum secondary spring which initially had a blocked vacuum port to the vacuum secondaries .It was brand new carb out the box as well. I always tune for max vacuum at tickover by balancing timing as well as mixture and tickover screws.
    If your vacuum is too low at that 1400 cruise it could be causing the secondaries to be opening too early and making it stumble. Higher tickover vacuum should move the effect elsewhere in the rev range which can be tuned with secondary vacuum springs then.
    Wiht Antons, also a T bucket we had to go several springs lighter to get the best performance.
    Just looked back at your initial post and I'm not understanding why you start at 9 " of vacuum and it's increasing as you accelerate ? Where is the vacuum gauge reading being taken from?
    London Heathrowish!
    7,723
    46
    I'd be looking at the timing curve as well. Play about with it a little. Try running without the vacuum advance as well and see if there is any affect? Where is it set to at present? What distributor and have you got stock advance springs or light?
    1. Marc 55 Chev Carb tuning
      By ozzie in forum Chat
      Last Post: 04-07-2010, 22:51
    2. holley carb plus rover v8 bits
      By harris66 in forum Stuff - WANTED
      Last Post: 31-01-2010, 18:58
    3. holley carb id ?
      By 100ev8 in forum Tech Discussion
      Last Post: 01-10-2009, 19:59
    4. holley carb question
      By vw2v8 in forum Tech Discussion
      Last Post: 29-08-2009, 12:56
    5. Holley carb
      By TATFINK in forum Stuff - FOR SALE
      Last Post: 03-06-2009, 10:09
