Holley or Edelbrock Carb
Results 1 to 10 of 12
    south east kent
    889
    35
    THE VIKING is offline
    What is the best choice of carb ? is for a 360 smallblock Chrysler and you reasons ?
    23,634
    Well that size engine is going to take a 600 cfm ,anything bigger and it will be boggy on the bottom ( assuming mild to middle spec engine ) .You need to check the exact spec is correct as on some carbs Edelbrock and Holley use different methods of measuring cfm .
    Some swear by Holleys but mostly people seem to swear at them I've always used Holleys and never had a problem but all of mine have been brand new purchases so no one else has been 'tuning' them before me.
    Vacuum secondaries as opposed to double pumpers is always another issue and there is a chart on the Holley website with lots of questions about what you want the carb to do that will guide you.
    I believe that Holleys are far more tunable than Edelbrock sbut I'll leave that to the better informed to discuss.
    I always try to be realistic in my approach to all part sof engine building. If it's primarily a street car then aim your build there .Ultimate bhp for the strip can be a pain to drive on the road if you only go racing a couple of times a year.
    lone wolf 58 delray's Avatar
    kent
    366
    499
    58 delray is offline
    always had trouble with holleys and no problems with edelbrocks myself. the holleys i've had always seem to overfuel no matter what i tried to do with them.
    south east kent
    889
    35
    Cheers Guys sounds like its going to be a edelbrock for me then as this is a road car that I want to enjoy driving and not be under the bonnet every time I take it out
    S.E London
    5,716
    513
    vince-305 is offline
    Yep holleys can be a real pain but so can the edelbrock
    I filled the sump with petrol with the holley due to the power valve (1 pop back and there normally fubar'd) but you can do somthing to prevent that from happening
    And with the edelbrock i washed the engine with petrol and filled the bores whilst pushing the car with the ignition on had a waterfall effect over the top of the carb down the inlet over the back of the heads on to the exhausts and about £20 out of pocket
    but i have found the edelbrock the better carb and mines too BIG for my engine
    Bit'z 'N' Piece's
    south east kent
    889
    35
    What size carb do you have vince ? and what size motor is it fitted to ?
    S.E London
    5,716
    513
    im running a 305 chevy which needs a 570 but im running a 600 not a lot of difference but enough and with the edelbrock you have metering rods and jets and different spring rates that are all changable plus the acc pump has 3 postions and you can buy jets and springs in sets at around £50 ish
    Bit'z 'N' Piece's
    up north
    1,987
    35kid is offline
    vince any holley built since 1992 should not blow power valves if there is a backfire, they were redesigned to stop that fault happening. they put in a check ball valve which closed in the event of a backfire stopping the diaphram rupturing.
    Wild Willie Fadster andy fadster's Avatar
    near glossop
    1,719
    58
    andy fadster is offline
    Edelbrocks versus Holleys....
    Edelbrocks have always worked straight out of the box for me. Holleys are poo. They leak and take your mind of the ball. You shouldn't have to be worrying about a carb leaking and well, for me holleys leak. Two Holleys later and I'm running edelbrocks.
    Quarter of a mile at a time...after that, its the Sat Nav
    489
    langy is offline
    I think Holleys get a bad press because they are usually old as people buy 2nd hand, To be honest i've never had a problem with a new Holley or Edelbrock, The Edelbrock is just as tunable as a Holley but i prefer Holleys for strip use and find Edelbrocks excellent for the road.
    1. Edelbrock carb for Rover V8
      By john64 in forum Stuff - FOR SALE
      Last Post: 27-04-2010, 19:06
    2. Holley or Edelbrock????
      By Pepsi Max in forum Tech Discussion
      Last Post: 14-04-2010, 17:26
    3. Edelbrock or Holley
      By john64 in forum Stuff - WANTED
      Last Post: 28-03-2010, 21:54
    4. Edelbrock performer 750 cfm carb
      By trevd in forum Stuff - FOR SALE
      Last Post: 15-01-2010, 17:52
    5. Edelbrock carb adjustment
      Last Post: 23-10-2009, 17:25
