how to fit a vinyl roof
Results 1 to 10 of 11
    Rods 'n' Sods Junkie vw2v8's Avatar
    wrexham
    395
    8
    vw2v8 is offline
    on a model y it had a large opening in the roof wich i filled in and now i need to stick a piece of vinyl on the top of the roof..i take i glue it on ..what do i do about the edges,is there a trim i can fit around it.what glue do i use?
    489
    langy is offline
    Blimey its a long long time since i have done a vinyl roof but you need to get a heat proof glue, Kev should have the spec for it somewhere, I would suggest a trip to your local sunroof firm as they could possibly sell you what you need.
    23,225
    You need to get a VERY high temp glue , 3m have a spray one in their range that is good for 100C , most of the heavy duty upholstery glues are only 75c and the normal stuff is 50 and that can peel inside on a hot day with windows closed.You would be amazed how hot a steel roof can get in summer.
    23,225
    I got my last can from these people
    http://www.parafix.com/
    wrexham
    395
    8
    vw2v8 is offline
    ok thanks for the replys..its fiberglass roof/car you see alot of ford pops with them this is the car back in the 80s,i want to do the same as the roof was but with black vinyl
    489
    langy is offline
    Arr i see what your doing now, Pop Brown does a kit for that job, I just done a similar think on a 3W coupe but the vinyl insert was already moulded in so was painted and then i used polished stainless bar with studs that were tightened from inside to hide the join.
    wrexham
    395
    8
    vw2v8 is offline
    Quote Originally Posted by langy View Post
    sound about the same thing as i was going to do...have you got any pics please...thanks
    489
    langy is offline
    I knew i should of taken some pics 8-(
    Quote Originally Posted by vw2v8 View Post
    917
    Mark Bull is offline
    Recently done this very job on my 32 5w.I would suggest that you take a mould of the roof so that you can take a replica out of it.This panel you make would want to be about 3mm thick.Cut it to the desired shape and rad the edges.Cover that in vinyl and stick it on to the roof of your car with stikaflex or similar.As it was moulded off your roof it will be a perfect fit.
    I did the same thing on a pickup cab about 4/5 years ago and its still on there as good as the day it was done,and the car is in daily use.
    If you go next door and look on the members rides sections there are a pic or 2 of the roof on my coupe.May explain things better?
    Mark
    wrexham
    395
    8
    vw2v8 is offline
    Quote Originally Posted by Mark Bull View Post
    Mark
    thanks for the info mark..had been watching your build up thread next door but couldnt post anything as im a non member..btw the car is very nice it looks like your not far off finishing..roof pannel what did you use to get a mould of the roof,my roof is allready painted ..were did you get your vinyl from..cheers f
    1. vinyl softener
      By evilzee28 in forum Tech Discussion
      Last Post: 24-02-2010, 21:38
    2. Vinyl to CD
      By Hemi Bucket in forum Chat
      Last Post: 19-01-2010, 00:28
    3. vinyl roof adhesive
      By camarodaz28 in forum Tech Discussion
      Last Post: 23-11-2009, 13:39
    4. vinyl roof kit
      Last Post: 04-11-2009, 19:59
    5. vinyl roof suplier
      By vw2v8 in forum Tech Discussion
      Last Post: 06-05-2009, 17:49
