How to start a 327 SBC?
Page 1 of 22 1 2 3 11 ... LastLast
Results 1 to 10 of 214
    Lower Kingswood, Surrey
    3,426
    185
    Mad Mark is offline
    I have re-built the engine and finally got it in the car, but it won't start!
    I have 6lb pressure of fuel and checked the timing so many times. I even took off the left rocker cover and watched the exhaust valve for NO 6 (Nearest the front) close and the inlet start to open to make sure I'm on NO 1 compression.
    I checked fuel, I have a squirt from the accelerator jets (and 6lb of pressure). I checked the spark on NO 2 and checked it sparked just as NO 1 timing marks come up to the marks.
    As I start to turn it over it tries to start (the turning seems to speed up a bit and it tries) and then goes into the constant turning with no sign of life.
    So, who has any ideas? HELP!!!
    Nov 2009
    stourport
    5,524
    7
    beach57 is offline
    Are you using an ign switch if so check you are not loosing power when it's in starter mode.ie still got power to ign when trying to start
    Official RnS Addict mikeyboy's Avatar
    San Diego.Calif USA
    2,422
    209
    mikeyboy is offline
    Left bank is 1357 right bank is 2468 . You sure you got the firing order right? Make sure both vaves are closed on #1 when the timing mark is at TDC
    There's no replacement for displacement.
    3,426
    185
    Mad Mark is offline
    I bypassed the switch for the starter solenoid, due to problems, so I have a push button and minimal wiring- but the ignition is still through the switch.!!
    3,426
    185
    Mad Mark is offline
    Sorry, left as looking from the front- working on the barst............
    2,4,6,8.
    Official RnS Addict farncombe pop's Avatar
    Farncombe Surrey
    4,274
    42
    farncombe pop is offline
    You did put the earth strap back on didn,t you ?
    Here to help !
    3,426
    185
    Mad Mark is offline
    Yes mate, or it wouldn't turn over! I thought I'd done EVERYTHING..................
    San Diego.Calif USA
    2,422
    209
    mikeyboy is offline
    Quote Originally Posted by Mad Mark View Post
    2,4,6,8.
    Yep,usaually its looking from inside the car
    8,746
    1755
    blackpopracing is offline
    Well if it's got fuel & a spark it should start.
    You could try loosening the dizzy, (mark where you think it should be first) and twist it a little either way when cranking. If timing is off then you will catch it one way or the other.
    Make sure battery is fully charged again before you next try.
    12,800
    hi mark, when you adjusted the tappets did you wind them all down tight or in order 3/4 turn from no free play at the pushrod? had this with mates who rebuilt engines before and had only done positive stop rockers previously. the valves could be part open even off the cam lobe.
    1. Drag Racing, where and how to start.
      By StueyT in forum On Topic
      Last Post: 08-01-2012, 20:37
    2. What cam to use in a sbc 327
      By newboldspeed in forum Tech Discussion
      Last Post: 05-12-2011, 20:57
    3. Anyone got an old copy of how to hot rod your SBC?
      Last Post: 28-02-2011, 17:12
    4. How to get started??
      By Kenny Chevy S10 in forum National Street Car Challenge (NSCC)
      Last Post: 24-12-2010, 17:13
    5. How to start a fight ...
      By Hot Rod Widow in forum Chat
      Last Post: 14-08-2010, 22:13
