I beam narrowing
Results 1 to 3 of 3
    Walsall
    681
    6
    Adey is offline
    I beam narrowing
    what is involved in narrowing an i beam, the one i have is 51 inch wide and would lke to make it 48inch. is it best to cut the 3 inch form the centre and make new batwing plates, or to cut both ends and re weld .
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Re: I beam narrowing
    Make the cut in the centre. Make the cut in one axle half so that you have a three inch "tongue" i.e. cut back the top and bottom of the beam. Then cut three inches out of the centre web on the other axle half. When you put the two halves together, you should have the maximum length of weld in the joint and an axle that's three inches narrower . Make sure that you make some kind of jig off the kingpin eyes or perch pin holes to keep the alignment when you weld the axle back together.
    Stuart.
    Hidden Content
    Walsall
    681
    6
    Adey is offline
    stueee
    many thanks
    i just need to work out where to apply the cut , as the axle has been drilled along its length.
  1. volvo axle narrowing
    By jifop in forum Tech Discussion
    Last Post: 31-07-2016, 21:08
  2. Narrowing volvo axle
    By bootlegger in forum Tech Discussion
    Last Post: 04-04-2010, 19:56
  3. Narrowing an 8.8" axle
    By matt100e in forum On Topic
    Last Post: 19-02-2010, 19:33
  4. Narrowing rack
    By CRAIG in forum Tech Discussion
    Last Post: 15-11-2009, 19:11
  5. Steering rack narrowing..
    By Magman in forum Tech Discussion
    Last Post: 09-07-2009, 08:13
