identifying a small block ford...
Results 1 to 5 of 5
    essex
    527
    79
    TOETAG is offline
    ive got a small block ford engine(block) it has 289 stamped in the valley,but how do you decifer the engine numbers,it looks like 05AE-6015E,and has 030 on the piston top,so i figure its been rebuilt at some stage,whats the limit on re-boring? and whats it worth? cheers fellas
    Got salt Briz's Avatar
    west norfolk
    1,301
    35
    Briz is offline
    You wont find actual engine numbers of ford lumps from that era. The number you quote is a casting number. The first 'O' is more likely to be a 'C' or 'D', since all ford casting numbers begin with the year ( C for 60s, D for 70s & so on) So its either a '65 or a '75 casting.
    The 'AE' means its a 289 / 302 from the Windsor plant, and the 6015 just means 'engine block'.
    Not sure how much bigger you can bore; probably .040. Maybe +.060.
    Official RnS Addict Mark H's Avatar
    West Lothian,Scotland
    732
    Mark H is offline
    As Briz said first character is probably C if it's a 289.
    Same casting number as mine which is a '65 289.
    C-1960's
    5-'65 model year
    A-full size car line
    E-engine
    6015-part number
    E-number of production changes(4)
    With this casting number,it will have the 6-bolt bellhousing flange instead of the earlier 5-bolt flange as used on the 260 and early 289.
    As far as I recall,recomended max over bore is +40.You may run into problems at +60.
    Mark
    old tart (was kc55) dualquads's Avatar
    croydon
    745
    737
    dualquads is offline
    when you bore to big on these the bores dont hold up and eventually crack, i think 40 thou might be the safe limit.
    kev
    i say, anyone for a spot of tiffin...
    essex
    527
    79
    TOETAG is offline
    cheers for the advice fellas
    1. Ford Small Block Intake Manifold
      By caprijunkie in forum Stuff - WANTED
      Last Post: 18-04-2010, 19:35
    2. Ford small block header
      By Lee in forum Stuff - WANTED
      Last Post: 25-03-2010, 20:03
    3. Ford Small Block Headers. £80
      By Lee in forum Stuff - FOR SALE
      Last Post: 03-03-2010, 21:34
    4. Small-type dizzy for small block FORD
      By talk_wrench in forum Stuff - WANTED
      Last Post: 03-12-2009, 12:46
    5. y block or small block ford carb
      By verr1908 in forum Stuff - WANTED
      Last Post: 03-08-2009, 18:10
