IFS design ?
Results 1 to 10 of 17
Thread: IFS design ?
    south east kent
    889
    35
    THE VIKING is offline
    IFS design ?
    I am going to build my own front IFS and have a few questions that I need answers to. I understand that in order to get the ackerman right I have to get the pivot point on the rack to intersect an imaginary line through the top and bottom wisbone pivot points. If this is the case and lets say the rack I have is a little short can I move the bottom wishbone in towards the centre of the car or if the rack is a little long can I move the upper wisbone pivot point out in order to get these pivot point to be in the right place ? And now the second question how do I determine the ride height that I want the car to sit at ? when putting this IFS onto the main frame rails ?
    489
    langy is offline
    S.E London
    5,697
    510
    vince-305 is offline
    I was under the impression that th Ackerman angle was to do with the imaginary line from the center line of the rear axle through the king pins/ ball joints and beyond and the steering ends had to be some where on that line
    IE if in front of the Axel the tre's would be closer to the wheel but if wee behind the would be closer to the center of the car
    And i found this out through help from Kev and Langy and i think one of em did post up a diagram on the NSRA
    But that was for my beam axle and not 100% what the difference would be for wishbones
    I MUST TYPE FASTER LOL
    Bit'z 'N' Piece's
    S.E London
    5,697
    510
    I have posted this before but ill do it again it might be useful
    http://streetrodder.automotive.com/9...les/index.html
    Again for a sraight axle not wishbones
    Bit'z 'N' Piece's
    south east kent
    889
    35
    Thanks for the replies as you can see I got mixed up with this and I ment bupm steer so is what i stated correct and can I overcome the issue I mention by the method I explaned ?
    Glasgow,Scotland
    2,123
    german8rcoupe is offline
    Quote Originally Posted by THE VIKING View Post
    Sorry, but this type of question says that you need to do much more studying before contemplating doing this yourself. The wishbone pivots ,there lengths relative to each other and the angle they mount at all play a huge part in how the suspension works(or not), so until you have that sussed you can't just move things around until it fits.
    Too big a subject to explain it all in one go. Loads of books on this so go read one, then read it again.
    west midlands
    2,813
    259
    stevie.t is offline
    Quote Originally Posted by german8rcoupe View Post
    well put, having built a few sets of a arms it is not as easy as you may think if you start moving a arms in in or out top or bottom you will throw out all the geomatry i can see what you are attempting to get your rack to fit but you need to no a lot more,there are several book,s to look at, i had one about raly cars that was very good ithink it was celled how to make your car handle? hope this helps im not trying to negative but as i said there is alot to no
    Notts
    168
    13
    6-71 is offline
    Just a quick question along similar lines.....if the vehicle was to be changed from steering box to steering rack, would I be correct in thinking that the steering arms do not need altering as the Ackerman angle remains correct? (standard factory suspension)
    23,279
    Yes, but rack conversions are a whole other ball game especially on a Mac strut car if you wnat it to handle as well as just turn the wheels in the correct direction.
    If you want to set up an IFS , read books about IFS , if you want Mac strut do the same , likewise beam axle. Ackermann is about the only interchangeable spec amongst them, each has it's own needs and settings.
    Check out the UKhotrods techs section for a basic overview re requirements for IFS.
    south east kent
    889
    35
    Have you a link Kev ?
    1. chassis design?
      By madmatttcustoms in forum Tech Discussion
      Last Post: 01-03-2010, 09:54
    2. Web design info
      By FlatheadFordV8 in forum Chat
      Last Post: 19-02-2010, 11:09
    3. Suspension design theory
      By dubwarrior2 in forum Tech Discussion
      Last Post: 09-01-2010, 17:54
    4. IFS/IRS Suspension design (for dummies)
      By TQ_uk in forum Tech Discussion
      Last Post: 23-09-2009, 01:10
