Ignition light on 1 wire alternator !?
Results 1 to 10 of 12
    Stroker Kustom Jim's Avatar
    Bath
    5,188
    2753
    Kustom Jim is offline
    QuestionIgnition light on 1 wire alternator !?
    Hi,
    got a 1 wire alternator to wire up, googled it and discovered that they don't have a 'dash light' igntion on facility!?
    Is that right?
    I got the alt by default, so will have to get over the dash light glitch.
    I do have an ammeter dial in car so will have an idea of charge etc.
    So does that mean I have to run the charging wire from the alt thru the ammeter then to starter?
    I do have the instructions with a single wire kit and it suggests one maxi fused lead to the starter and one to the fuse box!?
    Dunno about the fuse box lead as there's a main feed going there from the the starter anyway (batteries in the boot).
    Also, I do have three relays to feed under the bonnet so trying to find an insulated terminal like this to avoid too many wires lashed onto starter.
    Had a swatch at Premier and CBS but struck out Any ideas?
    Cheers!
    KJ
    first of many sparky questions to come!
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    One wire alternators don't have a warning light 'cos the current to excite the field comes from the one wire.
    Stuart.
    My Intro
    wolverhampton
    1,392
    redvictor is offline
    Quote Originally Posted by stueeee View Post
    eau contraire...
    They do need a warning light. You need a bulb with two connectors.Ign switched 12v to one side of the bulb,and the other side to the terminal on the alternator..
    Europe's quickest and fastest street legal car. 4.09 @ 191 - 6.27 @ 237mph so far...
    IVA legal too!
    Penn Autos/Andy Frost race transmissions.
    www.redvictor1racing.co.uk
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Quote Originally Posted by redvictor View Post
    eau contraire...
    Can you explain how that works then? The one wire is connected to the alternator B terminal at one end, and to the unswitched positive at the battery end, so how would the bulb ever light with 12v on both sides of the filament whenever the ignition is turned on?
    Stuart.
    My Intro
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Quote Originally Posted by Kustom Jim View Post
    Hi,
    Cheers!
    KJ
    If you want to connect to your ammeter (check the full scale amperage first-it may be a lot less than your alternator will poke out when the battery is a bit flat, you may end up with the needle jammed off the scale) just connect from the alternator B terminal to the load side of the ammeter, the battery will be connected to the other side of the ammeter anyway.
    What about using one of these boxes for your power connections:
    http://www.vehicle-wiring-products.e...tconn.php#jbox
    Alternatively, you could make something up using some 2BA or M5 brass screws and nuts mounted on a lump of Tufnol or similar engineering plastic, this is what I have hidden under the dashboard of my old truck.
    Stuart.
    My Intro
    wolverhampton
    1,392
    because terminal B is a ground until the alternator starts creating current so i'm led to believe.
    I'm not a time served electrician but the guy who told me how to do it is,and the cadillac(and my own car)that i fitted a one wire alternator to works the way i described.
    Surprisingly the light is on when just the ignition is switched,then when the car starts the light goes out AND it charges too!
    IVA legal too!
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Don't know about the alternator on your car, but a standard 1 wire alternator is connected to the +12V side of the battery i.e. a permanent live, if it had a ground connection on the B terminal it would flatten the battery PDQ.
    Stuart.
    My Intro
    wolverhampton
    1,392
    But....if it had 2 wires like both of the ones i described had..
    Forget everything i said.It's the pills i tell ya.
    IVA legal too!
    Rods 'n' Sods Junkie rockinrich01's Avatar
    Devon!!!
    249
    48
    rockinrich01 is offline
    I've wired mine up and it works. You have a 12v switched supply to lamp, but don't ground lamp wire it to small spade terminal on alternator, And other small terimal goes to a 12v supply to monitor voltage for built in reg in alternator!
    Heres a link to a pretty picture...http://mightymo.org/public_html/imag...re/DelcoSI.jpg
    Cheers Rich
    RACE WITH THE DEVIL!!!!!
    wolverhampton
    1,392
    That's not a 1 wire,which is the mistake i made..lol
    A one wire has just the big thick wire and nothing else.I was thinking one wire as in one wire other than the thick one.
    IVA legal too!
    1. ignition to coil wire
      By hepcat in forum Tech Discussion
      Last Post: 09-03-2010, 22:40
    2. Single wire alternator - recon'd
      By Flathead Meltdown in forum Stuff - FOR SALE
      Last Post: 17-01-2010, 18:59
    3. rv8 electronic ignition kit
      Last Post: 18-09-2009, 13:23
    4. Rover V8 SD1 ignition ?
      By Tarmac Tanner in forum Stuff - WANTED
      Last Post: 05-09-2009, 15:22
    5. one wire alternator , wire amps help
      By Steve 5-6-7 in forum Tech Discussion
      Last Post: 28-07-2009, 21:28
