Injector Cleaner. Anygood?
Results 1 to 5 of 5
    Consett, Durham
    998
    8
    leepop633 is offline
    Im having a prob, or maybe not, it maybe normal, with my 300TDi Auto Disco. Since i bought it and when first started, it wont pull away very easily as though the fuel aint getting through. If you rev it a few times then its fine but a sluggish to rev the first couple. Its had a new lift pump and a few new filters. I thought it might of just been the cold fluid in the TC needing to swish round. A friend took off the inlet manifold and intercooler for me so i could clean them out as already had the EGR done. While it they were off we renewed the old turbo pipes aswell. Next day, it was flying and a different animal. Took it to my mates about 15 mile away, then to come home it was back to old style really really sluggish, (more than normal). Anyone any ideas, it isnt EDC either or does injector cleaner actually work as only getting about 21mpg if lucky around the doors and 24 mpg on a run.
    Herts
    4,617
    224
    WB54 is offline
    Re: Injector Cleaner. Anygood?
    Quote Originally Posted by leepop633 View Post
    has it gone into some sort of safe mode ? have you had the ECU read for fault codes ?
    Col
    Heavy Oiler Col's Avatar
    Feb 2010
    berks
    2,504
    299
    Col is offline
    Injector cleaner is an ideal first call. If that doesn't work, then get injectors tested. Don't know where you are but I'm Reading /Southampton area and can test them for you. Regarding the poor starting, You could have an air leak at one of the filters you have replaced. You should oil or grease the new seals when you change them.
    EDIT: For best results when using inj cleaner, drain the fuel filter and fill it with cleaner, then stick another bottle in the tank (then drive it round the block like you stole it)
    Consett, Durham
    998
    8
    Cheers guys. Mine done have an ecu for engine which is why i went for pre edc after selling my v8i i wanted no gadgets or electrics, . Fuel wise is starts fine and ticks over fine it is just reluctant to rev or pull away unless you give it a few hard revs then it will pull away fine. When its been revved aswell it dont hoy nowt out the back either. Cheers for the injector offer dude but im in Durham. Will try the cleaner first but defo seems like fuel to me as mpg is pretty bad even for a TDi Disco. Aint much better then me V8i and that was nicer to drive and sounded better
    Consett, Durham
    998
    8
    Sorry Si, i only posted this in the chat as wasnt Rod related. Thought was only rod stuff in the Tech.
    1. lotus twin cam air cleaner
      By popinoz in forum Stuff - WANTED
      Last Post: 07-05-2010, 16:37
    2. oil bath air cleaner
      By pistolero in forum Tri Chevys, Spirit Of the Fifties and the Tuck Up Squad boys
      Last Post: 15-03-2010, 10:32
    3. Edelbrock air cleaner
      By capriga in forum Stuff - FOR SALE
      Last Post: 23-02-2010, 19:51
    4. holley 4 barrel NOS injector plate
      By karrionchris in forum Stuff - WANTED
      Last Post: 03-02-2010, 14:43
    5. Screen cleaner
      By Stitch in forum Chat
      Last Post: 06-12-2009, 10:59
