It's in again...............
Page 1 of 15 1 2 3 11 ... LastLast
Results 1 to 10 of 146
    Lower Kingswood, Surrey
    3,426
    185
    Mad Mark is offline
    I have replaced the 327 in the car and fired it up today. It ran.............
    ....for a few seconds and then spluttered out of life and blew back through the carb. Tried to start it again and it didn't want to play.
    I wonder if I have the rockers set too tight. I tightened down on the nut until it was difficult to turn with my fingers and then gave it another 1/2 turn, as I have been taught, but I wonder if I should only tighten until I loose the slap on the rocker (up and down) and then give it a half turn. I'm sure the timing will need to be adjusted, but I think it's close enough for now to start it.
    Any ideas? BTW, I have fuel!!
    nottafukinchancingham
    7,757
    56
    Torment is offline
    Too tight. .has it got hydraulic lifters...???
    57 bel air wagon
    540cui altered.
    3,426
    185
    Mad Mark is offline
    Yes they are
    Jun 2009
    bromley, kent
    1,390
    390
    prostreet70gto is offline
    Hi mark
    i did say slight resistance....not till you cant turn them. you should just about feel the pushrod being touched by the rocker....and then 1/2 a turn mate
    I normally get it to the point its touching, then back it off again. Do the same again a couple of times til im sure its not holding on the nut or anything else and then with it JUST BARELY touching the pushrod, give it half a turn. They will be silent but zero lash at that point
    3,426
    185
    Mad Mark is offline
    Thought so..................................... Thanks Simon!!
    Pillock!!!:****er:
    London Heathrowish!
    7,708
    46
    Plumpcars is online now
    It's all about feel Mark and I would say you have been way too heavy handed.
    up north
    1,989
    35kid is offline
    it sounds more like timing is your issue rather than lifters being overtightened. i normally do what you do, twist in your fingers until its tight but then give it 3/4 of a turn - but thats what the cam manufacturer recommends.
    London Heathrowish!
    7,708
    46
    Problem with that Mark is that everybody's idea of twist is different. I've watched a few people really struggle with it over the years. Having said that why is the timing not right if you've just built it up? It should be close?
    Stroker Kustom Jim's Avatar
    Bath
    4,729
    2608
    Kustom Jim is offline
    Interestingly I saw and tried a while ago, a very thin feeler gauge old school between rocker and valve and then tightened down 1 full turn, or summat, can't remember.
    I'm sure there's a way to work out what a turn equals in millimetres etc, then you can add that feeler gauge extra bit on.
    It makes em all the same, as has been said feeling the drag etc is quite vague.
    but only if you have roller rockers which give a flat surface same as valve tip,
    Them poxy stamped rockers aint all flat.
    Failing that Dr Dees method in the Tech section was the best 'normal' way I tried.
    Anyhoo, my sbc runs a bit quieter now.
    HTH
    Nov 2009
    stourport
    5,524
    7
    beach57 is offline
    Was told to do it while it's running,get old rocker cover then open the top to set them .
    1. My 57 and the Battersea Boys (again).
      By ken57 in forum History Archive
      Last Post: 16-02-2017, 20:07
    2. Replies: 0
      Last Post: 07-05-2009, 11:01
    3. vin likes diesel feels wanted again
      By vin likes diesel in forum Who are ya ??
      Last Post: 27-04-2009, 15:07
    4. It's that bloody striper again !
      By tootall in forum Who are ya ??
      Last Post: 24-04-2009, 19:55
    5. It's me again...
      By Flat Ernie in forum Who are ya ??
      Last Post: 23-04-2009, 04:13
