Jag' hub question
Results 1 to 3 of 3
    South Norway
    208
    staleg is offline
    Jag' hub question
    What's this? Is it for greasing the wheel bearings? How do I do that?
    Official RnS Addict harris66's Avatar
    Jul 2009
    solihull
    2,385
    79
    harris66 is offline
    yep, there ahould be a standard grease nipple on it, wheel off, grease gun on and pump it in. not sure what that is though from that shot?
    i want cubic inches! lots of em!!
    Aug 2009
    down south
    100
    Rover V8 is offline
    Hi Guys,
    The grease nipple that you refer to is on the under side of the lower bearings, as you say pump it in, shouldn't normally need loads though, should see the grease coming out of the seals either side of the lower wishbone when you have filled it up.
    The cap that you are showing is the grease cap for the hub bearings, you can prise this out with a small screwdriver then pump grease in, we used to pump it in whilst the motor was fired in drive ticking over (be extra carefull of moving parts though) don't over fill.
    Hope this helps,
    Cheers,
    Mike C.
    1. Fasten the drive shaft to the Jag' IRS?
      By staleg in forum Tech Discussion
      Last Post: 18-12-2009, 17:29
    2. Jag' rear bump stop?
      Last Post: 15-09-2009, 19:08
    3. Jag' hub felt bushing replacement?
      Last Post: 25-08-2009, 05:16
    4. Oil leaking Jag' rear...
      Last Post: 21-08-2009, 13:47
    5. MOT question
      By jim351 in forum On Topic
      Last Post: 17-05-2009, 10:02
