JAG LSD into 4ha axle questions...
Likes Likes:  1
Results 1 to 9 of 9
    Dec 2018
    85
    cresta pa is offline
    Ive read some articles about this, the jag IRS LSD (into a scimitar 4HA ) ring gear needs a spacer, is there anyone making these? thanks
    Jul 2009
    three holes, wisbech, cambs
    5,183
    1003
    352 kum is offline
    a jag axle is a 4ha
  4. Likesmygasser liked this post
  5. #3
    Sep 2011
    Kings Lynn
    3,252
    465
    brading is online now
    PM " stueeee " see if he can help as he has put a LSD in a 4HA.
  6. Remove Advertisements
  7. #4
    Jan 2011
    Surrey
    277
    7
    roymck is offline
    The spacer is for the endfloat on the halfshafts . On the Scimitar axle the endfloat on the halfshafts is adjusted with shims with a spacer that goes through the diff to but up against the opposite halfshaft. So removing or adding shims on one side actually adjusts the endfloat on both sides of the car. Fitting a LSD there is no way a spacer can fit in the LSD for the halfshafts so you need a 2 little slugs machined up to fit in the diff and each halfshaft buts up against this so endfloat on either side has to be adjusted with shims separately.
  8. #5
    Dec 2018
    85
    Im on about the LSD unit, it sits the jag crwon wheel about 6mm from the pinion when fitted in the scim case.
  9. #6
    Sep 2011
    Kings Lynn
    3,252
    465
    " roymck " the the spacer in this post is the one that has been mentioned.
    https://www.rodsnsods.co.uk/forum/te...light=4ha+axle
  10. #7
    Dec 2018
    85
    Yep, thats what I mean, its 2:88 to 1 ratio, I need to get the spacer, I quess I need to get it apart & check exactly what thickness I need. good info thanks
  11. #8
    13,687
    so just a ring gear spacer, in the link he made the spacer ring himself so any machine shop could repeat it for you.
  12. #9
    Dec 2018
    85
    I have the gear to make said spacer, just thinking maybe buy one save the hassle...thanks
