Jag rear wheel bearings
Results 1 to 6 of 6
    nowhere
    7,053
    2407
    nobody is online now
    One for the mechanics
    Just replaced them .this is a xj40 rear.
    These type you just put everything together and torque the main nut up.on doing that,the hubs are pretty hard to turn by hand.
    Is this normal.ive used quality branded bearings and reassembled as it came apart.
    Once we run up the truck there in,will they loosen of slightly.
    Thanks
    23,481
    I've not worked on the XJ40 raer end but on earlier ones the big thick spacer before the nut has to be a worked out value to set your end float .
    Sep 2019
    Nr Malvern, Worcs
    128
    budetta is offline
    Same here , done loads of E type /S type bearings but not XJ40 . Did have (should still have) some spacers .OK just did search and there are spacers and it should have . 076mm end float.
    nowhere
    7,053
    2407
    thanks
    putting them on to the axle made them easier to turn.
    they do have a special one time only nut,as ive found out
    May 2016
    S E London
    918
    22
    timbo56 is offline
    Edited as I can't remember which way the spacer sizes work.
    https://www.youtube.com/watch?v=6n71TNpDULc at about 10.50min, it's the early type but the principle is the same.
    If you leave it as it is the bearing will seize when it gets hot
    May 2016
    S E London
    918
    22
    timbo56 is offline
    ****ed that one as well
