Kin brakes are still giving me a head ache.
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    Official RnS Addict Bel Air Lugosi's Avatar
    Aug 2009
    Sunny Whitby
    1,779
    249
    Bel Air Lugosi is offline
    OK...... I have drilled the pedal to align the brake rod.
    I have replaced a broken pedal return spring.
    I have the Wilwood bias valve almost completely open.
    The brakes arent binding or sticking on anymore.
    The problem Im having now, is that the brakes have no feel to them.
    By this I mean the pedal feels solid. Sort of on / off as opposed to progressive.
    I have to anticipate braking because if I just dab my foot on the brake, Everything locks up.
    There is no... The harder I push, the more braking there is. Its just on or off brakes.
    I have a one way valve in the vaccum pipe from the carb to the servo. It didnt come with the kit. Iv used them before without any problem. Could this be my problem? Unlikely in my mind.
    Life was so much easier when it had drums all round. If I hadnt sold all my drum bits I would have changed back by now. Its driving me mad.
    Its just horrible to drive.
    I just leave it in the garage now. Only drive it when I really have to. Thats no fun.
    Any help is good help. Thanx.
    If its low n black n shiny n sparkley n loud n spitting fire....... It's probably mine.
    [email protected]
    www.whitbykustom.com
    http://www.facebook.com/whitbykustompaul
    22,830
    How much actual pedal travel to lock out and how much is that at the master cylinder pushrod. ?
    What bore m/c now and before on the drums?
    Official RnS Addict ALS57's Avatar
    London
    1,223
    169
    ALS57 is offline
    Have you been through the CPP trouble shoot guide? pretty much the bible on brakes.
    Did you put in a proportioning valve?
    Given you're having so much bother might be good to detail the spec on all your components and pics etc.
    Aug 2009
    Sunny Whitby
    1,779
    249
    One of the main problems is that I have no spec. How do i measure all these things? Pull it all apart and measure them all?
    [email protected]
    Lower Kingswood, Surrey
    3,426
    185
    Mad Mark is offline
    Try Welcome to TriFive.com, 1955 1956 1957 Chevy Forum
    Some very clever folks over there and they may have used the same set-up that you have!
    Worth a try.........
    Deed Blat Cuba
    Sep 2009
    tring
    125
    36
    avengerboy1 is offline
    sounds to me like the rod is the problem similar thing happen on my mate mk 2 escort we check everything over and over then went to change m/c and found it was locking it self slight adjustment and hey presto might be worth a look
    22,830
    My bits are easy to do .
    Steel rule from the floor to centre of pedal pad, depress brake pedal fully and remeasure.
    Crawk up under dash until you see back of servo and pushrod.
    Measure from the outer edge of the servo to where the pushrod is attached to the pedal,push pedal fully down and remeasure same distance.
    While you are under there also measure from centre of pedal swivel /pivot to centre of where pushrod attaches, then measure from pedal pivot again to centre of pedal pad ( in a straightline ,ignore any pedal shape ).
    Don't get your mohican trapped in any springs etc
    Jul 2010
    liverpool
    320
    90
    jackzx10 is offline
    Ditto.. check your pedal pivot to pushrod / pushrod to pedal ratio.....dont want to sound daft but you do have freeplay in the pushrod dont you
    London Heathrowish!
    7,708
    46
    Plumpcars is online now
    This is a kit system for a 57 I'm assuming? As others said I would be checking the pushrod freeplay but I think I mentioned before that many in the States had not got these systems to work very well using a Wilwood type proportioning valve. It seems that a factory combination valve works much better and although non adjustable it gives a well balanced system.
    Aug 2009
    Sunny Whitby
    1,779
    249
    I was told by someone to leave the proportioning valve out.
    Someone else on my last brake problem thread mentioned they had a factory valve They didnt need. I could make use of it.
    Cant remember who it was. I'll go check the other thread.
    Im off into the garage shortly. I'll take measurements.
    I could be some time!
    [email protected]
    1. They are still out there!!
      By mikeyboy in forum On Topic
      Last Post: 06-02-2011, 13:53
    2. Retro pics are thy still alive ?
      By pat57 chevy in forum History Archive
      Last Post: 02-02-2011, 23:26
    3. What are you still paying for ?
      By 57peppershaker in forum Chat
      Last Post: 20-01-2011, 19:48
    4. my brakes are crap
      By stevie.t in forum Tech Discussion
      Last Post: 26-07-2010, 22:29
    5. Replies: 41
      Last Post: 14-02-2010, 21:52
