Lack of power under load
Results 1 to 10 of 20
    Rods 'n' Sods Junkie stevo1980's Avatar
    Jun 2015
    feltham middlesex
    125
    9
    5
    stevo1980 is offline
    Hi can I get some advice before I go any further, long story so bare with me...
    I rescued a 59 caddy that had been sat for 9 years. Have had absorbs of problems with starting and running, I now have got a loss of power when the car gets to about 30mph, it's fine driving it around the estate at very low speed's. So far it's had plugs,leads cap rotary arm, electronic ignition upgrade, timing set, new carb, fuel filter, and now I'm thinking of changing the mechanical fuel pump to an electronic one, the mechanical one is a sealed unit so I can't look inside. Am I doing the right thing? Or is there something else I'm missing. There also doesn't seem to be any vacume leaks either. The car starts and idles and runs at low speed's great. I don't want to give up on it as it's a nice car just been neglected for years. Thanks
    Jun 2015
    feltham middlesex
    125
    9
    5
    When I get the lack of power it's like there's not enough fuel and tried to cut out.
    Aug 2009
    braintree
    14,069
    69
    Darren West is offline
    Are the fuel lines totally clear
    Mr Cadillac :-) Motorama's Avatar
    Buckinghamcestercostershire
    1,717
    11
    Motorama is offline
    i would also check fuel lines, make sure it isn't blocked or crushed, try blowing it through, I've had more Cadillacs than you can shake a stick at and never had to fit an electric fuel pump. A new manual pump is cheaper than a decent electric pump and saves all the hassle anyway. Have you tried running the car from a can or other fuel supply to eliminate the fuel lines
    Looking for a 50s car, Cadillac, Buick, Pontiac, Oldsmobile, Chevy, cash waiting. Message me or call 07836 349356
    Jun 2015
    feltham middlesex
    125
    9
    5
    Hi fuel tank was removed and cleaned and new lines put on just before I got it. So I'm assuming that's ok.
    It drives lovely until you get to 30-40mph
    Feb 2013
    uranus
    2,144
    ivanhoew is online now
    fuel filter ? there may be a blocked filter in the line somewhere , or maybe the carb has a little filter in the fuel inlet that is clogged .
    up north
    1,987
    35kid is offline
    don't assume anything. fuel lines nowadays have a habit of getting gummed up due to todays fuel. I would pull them all and replace them with appropriate fuel line.
    Jun 2015
    feltham middlesex
    125
    9
    5
    Hi fuel filter housing removed filter replaced and refitted, has had a new carb too. I will check the fuel lines again but I'm certain they are ok. It's strange that it's fine until higher speeds that's why I thought fuel pump. Probably missing something obvious lol
    1,717
    11
    Motorama is offline
    Is it revs related rather than speed related, if you put the shifter in a lower gear does it bog down at the same revs. Did you fix the transmission?
    Andy
    Jun 2015
    feltham middlesex
    125
    9
    5
    When it started playing up i shifted it into a low and tried it and it done it again so I shifted it into neutral and it tried to cut out, I blipped the throttle a few times and it came back to life. But then as I set off again it played up again. The transmission slips into second still.
    1. 5.7 V8 SBC backfire through throttle body when under load?
      By carswaps in forum Tech Discussion
      Last Post: 26-08-2014, 13:41
    2. rover v8 twin turbo loses power under load
      By mcmental in forum Tech Discussion
      Last Post: 26-04-2013, 20:59
    3. Lack of power
      By plumcrazee in forum Tech Discussion
      Last Post: 18-04-2013, 17:39
    4. HELP!! Chevy pickup runs rough under load
      By hippogt in forum Tech Discussion
      Last Post: 10-01-2013, 19:13
    5. down-under
      By kiwi in forum Who are ya ??
      Last Post: 26-04-2009, 07:44
