Losing Water
Results 1 to 10 of 39
Thread: Losing Water
    Jul 2012
    isle of man
    247
    8
    ganzaigeorge is offline
    Losing Water
    Hi,running a 302 in a "Pop,flip front,no wings,no inners,so fairly open.....runs 13s on the strip,been running fine,temp reaches 90 slowly then at 94 ish number one fan comes on and brings temp down to 86 where it will stay until I hit traffic then the procedure starts again.I have fitted a small alloy expansion tank and fairly recent custom built 5 core rad has 15lb cap.There are NO visible leaks anywhere but the expansion tank has been going dry for a while now,I renewed head gaskets last month,just in case but it has nt solved the problem oh thermostat was. Recently fitted and I checked it. Before putting it in ,a160 degree.Then went on a 13 mile run yesterday and every time I stopped, steaming water gushed out of expansion tank overflow. got home and radiator was short of about 2 pints!Thinking I had a blocked thermostat I removed it,,did the same run today,average speed 45 with occasional bursts up to75 plus.This time no gushing steam BUT again radiator needed 2 to 2.5 pints,motor showed no signs of overheating and temp was ok.TOok rocker covers off. ,NO mayonnaise anywhere,oil dipstick fine,water in rad looks fine too,so what's causing the waterloss???I took bottom hose off yesterday and ran water through,no problem.IT seems water is being lost when system is under pressure,when I'm driving? Any ideas?
    Jul 2012
    isle of man
    247
    8
    forgot to mention,on start up water comes out of both exhausts leaving a noticeable splash,!This has been like this for ages!
    May 2010
    lichfield staffs
    4,451
    407
    streetfighter is offline
    don't like to say it but it sounds like a cracked head, especially if you have done all the other stuff you mention.
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Picture of the rad location and header tank location may help George.
    Oct 2012
    surrey
    638
    2
    can you either borrow or take it to a local mot place and do a sniff test, to check for gases in the radiator water.....
    neil
    Jul 2012
    isle of man
    247
    8
    Quote Originally Posted by streetfighter View Post
    . The heads looked fine when I cleaned them up,the old gaskets showing no signs of anything bad
    Jul 2012
    isle of man
    247
    8
    did a sniff test a while back and it was fine,However things might have changed '
    23,734
    Head on picture of the set up would be good but I take it that it's got worse since you fitted the new rad ?
    Did you bleed the system when you changed the rad ?
    Jul 2012
    isle of man
    247
    8
    rad is in usual place about 11" behind front grille,unobstructed direct airflow.Kenlowe top o the range 2 speed fan behind rad so it pulls air through, small water bottle style header tank behind rad to one side,top level with rad top,sorry no photo at present
    Jul 2012
    isle of man
    247
    8
    rad was fitted when I bought the pop 2years ago, I had 5. Core rad specially made as I have a fear of Overheating motors,so it's been in 2years but pop only put on road 6 months ago. So pretty we'll new.............
    1. bbc water pump
      By 58 delray in forum Stuff - WANTED
      Last Post: 24-06-2009, 11:58
    2. Rover p6 v8 water pump (new)
      By Street in forum Stuff - FOR SALE
      Last Post: 05-06-2009, 13:28
    3. Rusty water
      Last Post: 16-05-2009, 08:00
    4. Water pump
      By sidspop in forum Stuff - WANTED
      Last Post: 02-05-2009, 16:29
    5. ..... come on in the water's lovely !
      Last Post: 20-04-2009, 21:34
