Lowering a car with transverse leaf springs
Results 1 to 4 of 4
    Rods 'n' Sods Junkie mgleadow's Avatar
    Mar 2010
    Sheffield, S25
    125
    22
    mgleadow is offline
    I'm planning a project if the right car turns up - I want a Pilot and I want to drop it a few inches. I was thinking this would be fairly easy as I assumed it was on leaf springs and I could use lowering blocks, but it seems it uses transverse leaf springs front and rear.
    From what I have managed to scrape together online lowering these involves either replacing the spring or having the eyes re-rolled. How expensive is this likely to be and is it worth it or should I drive at stock height for a few years until I can afford to completely redo the suspension with a more modern technology?
    The idea is to get a cool car on a budget and then over time keep improving it - but I want something I can drive straight away ideally.
    I'm a grown up member now ! kryptonite67's Avatar
    Sep 2009
    ayr ontario aer kid!
    88
    2
    kryptonite67 is offline
    if you can find a spring specialist in your area it doesnt cost too much to reverse the eyes, or they could de-arch your springs as well so the spring rate is still right for the car,
    Mar 2010
    Sheffield, S25
    125
    22
    mgleadow is offline
    Ah cool, cheers for that. What would the implications be for steering and suspension geometry?
    What about lowering spindles (dropped spindles) for the front? Do they work, and are they better or worse than having the spring changed? Or are they not even an option on a Pilot - I believe it has a live front axle, would a dropped beam/tube make more sense?
    As you can see I've seen various methods for doing this but am not sure which works best in which situation.
    Banjo snapper. Hemi Bucket's Avatar
    Knocking one out.
    3,507
    998
    Hemi Bucket is offline
    Reversing the spring eyes will lower each end an inch, for the front you could ask Jerry Denning if as he drops I beams in the traditional way, I'll PM you his number.
    How'd the weekend go? Well, at the moment it looks like a dolphin that's been caught in a boats propeller.
    1. Lowering a leaf spring
      Last Post: 20-05-2010, 19:47
    2. Replies: 6
      Last Post: 13-05-2010, 20:53
    3. Sierra lowering springs
      By Epy in forum Stuff - WANTED
      Last Post: 27-03-2010, 09:33
    4. Seeking help :How to specify a transverse leaf spring
      By doctor rod in forum Tech Discussion
      Last Post: 02-03-2010, 21:29
    5. leaf springs
      By 34 boy in forum Tech Discussion
      Last Post: 28-06-2009, 15:49
