Lucas 35DE8 Distributor Wiring - Rover V8.
Results 1 to 9 of 9
    Rods 'n' Sods Junkie fingers's Avatar
    Mar 2010
    Rivenhall, Essex
    496
    64
    fingers is offline
    Afternoon all.
    My Rover V8 is using a Lucal 35DE8 Distributor and the stupid big and stupid expensive ballast resistor failed. Rather than spend £110 on a new resistor (yes they really are that expensive. Ballast Resistor 9BR for vintage & classic cars) I thought I would see if it could be made to run on a normal 1.6 Ohm resistor? And it can! Ignition re-wired with a normal ballast resistor and she bursts to life with a quick flick of the key .
    For those who may find themselves in the same scenario, the proper way to wire it in with the lucas 9BR resistor,
    And my way,
    I love it when a plan comes together .
    12,561
    so looking at your diagram you could just use a 12v non ballast coil and connect the 2 wires from the dizzy to each side of the coil, red/blk to +ve side/ign live and wh/blk to -ve side/tacho'. cool.
    Rods 'n' Sods Junkie DEVONMAN's Avatar
    Oct 2010
    Croydon
    378
    7
    DEVONMAN is offline
    But you would then loose the benefit of the enhanced spark during cranking.
    12,561
    not if you had a decent 12v coil
    Oct 2010
    Croydon
    378
    7
    DEVONMAN is offline
    Which 12v coil would you recommend for a Rover with a 35DE8 dizzy running without a ballast resistor?
    Mar 2010
    Rivenhall, Essex
    496
    64
    fingers is offline
    I would imagine any internally ballasted coil would work?
    This system if wired in using the Lucas resistor pack is ballasted by 1 ohm when cranking anyway, and being electronig IGN will probably start without the 12v kick while cranking. I will pull the starter feed from mine at the weekend and she how she fires from cold with constant 1.6 ohm ballast?
    Sep 2011
    Kings Lynn
    2,869
    332
    brading is offline
    Have a look on this site they have a range of coils
    Ignition Accessories
    Sep 2011
    Kings Lynn
    2,869
    332
    brading is offline
    12,561
    ballasted coils were made to reduce the voltage at the points so lessening the arc which extended points life. the full 12v that bypassed the ballast resistor gave a 'kick' when starting. as you can see from both of your diagrams the module in the dizzy is fed 12v via the red/blk wire all the time. so it's only the ht side that's boosted on crank when using a ballasted coil with electronic ignition. the normally 9v coil that's fed it's 9v via the resistor gets a full 12v when cranking by bypassing the resistor making the coil give a bigger spark for that short time. stock coils (ballasted and 12v) were 20,000v at best on the ht side, there are 12v coils available now that give up to 3 times that so are fine on there own.
    1. Wiring Help with Lucas Alternator
      By Bigdawgv8 in forum Tech Discussion
      Last Post: 22-09-2014, 21:08
    2. Wiring an Autometer Rev counter ?
      By Tarmac Tanner in forum Tech Discussion
      Last Post: 28-09-2009, 15:39
    3. Wiring loom
      By highlandrodder in forum Tech Discussion
      Last Post: 27-07-2009, 21:34
    4. wiring w/motor
      Last Post: 09-07-2009, 13:11
    5. indicator wiring problem!
      Last Post: 21-06-2009, 17:41
