Master Cylinder Bore Sizes.
Results 1 to 5 of 5
    I'm a grown up member now ! BillyBones's Avatar
    May 2010
    East Kilbride
    24
    4
    BillyBones is offline
    I am replacing the 5/8 inch bore brake master cylinder on my Jago T bucket and I have noticed some for sale which measure 3/4 inch which are a fair bit cheaper. Would changing the bore cause problems with my system? It has Anglia 105e drums at the front and Cortina mk1 drums on the rear. Thank you.
    Rust buster...
    Sep 2011
    Wisbech
    602
    flak monkey is offline
    It will shorten the pedal stroke (less feel/harder pedal) and need more pedal effort for the same stopping power.
    Hornchurch, Essex
    2,524
    9
    30psi is offline
    Going from 5/8's to 3/4 will increase the fluid output by 44% and therefore make the pedal shorter by about 30%
    '62 Ford Thunderbird
    '81 Datsun Bluebird SSS Turbo
    23,556
    Quote Originally Posted by flak monkey View Post
    He's right you know ! /\ 3/4 is designed for disc / drum set up and will , due to decreased line pressure make you brakes worse.
    May 2010
    East Kilbride
    24
    4
    Thanks very much for your help.
    1. brake master cylinder size?
      By AVG in forum Tech Discussion
      Last Post: 04-11-2011, 09:38
    2. Calculating master cylinder size?
      By Rob_Che in forum Tech Discussion
      Last Post: 06-10-2011, 08:42
    3. What size master cylinders?
      By Lee in forum Tech Discussion
      Last Post: 14-09-2011, 15:13
    4. 39-46 Ford Master Cylinder
      By RustyA in forum Stuff - WANTED
      Last Post: 21-07-2009, 09:04
    5. What clutch master cylinder?
      By Mudgie in forum Tech Discussion
      Last Post: 25-05-2009, 19:32
