mazda front suspension
Results 1 to 8 of 8
    Rods 'n' Sods Junkie bandqpaul's Avatar
    Jan 2010
    epsom
    348
    52
    bandqpaul is offline
    Smilemazda front suspension
    Lost out on a cortina crossmember i wanted for a new project i've just got,anyone on here ever played with mazda front suspension on a rod,i was looking at RX7 or MX5 anyone able to help?
    The project is an 1940 Austin Ten which hopefully will sit on the YSR 1929 A chassis i got from Kapri if this helps
    I'm a grown up member now ! vinnythespud's Avatar
    Jul 2009
    bradford
    70
    vinnythespud is offline
    i've got a generation 2 mazda rx7,i can post some pictures and take measurments if it's of any help to you.
    Jan 2010
    epsom
    348
    52
    Talkingcheers
    Hi Vinny,thanks for the offer i will take you up on it soon,I'm looking at some MX5 bits on friday the main item that i'm interested in on the RX7 is the uprights because of the 5 stud wheel pattern and whether i can get them on the MX5 arms,I know i'll probably have to make alts and the arms are steel on mx5's so easier to mod if needed,if not i might try the complete rx7 set up althought they are a bit rarer.cheers paul
    Jul 2009
    bradford
    70
    as far as i know the mx5 is on a double wishbone set up,my rx7 has struts,now sure if the hubs will swap over though.the stud pattern is 5 stud 4.5 inch pcd,same as mopars , fords and most other jap stuff.
    west midlands
    2,819
    259
    stevie.t is offline
    look at beardsmore brothers site there building a morris 1000 based on a mx5, there is plenty of imfo a build pics,
    Jan 2010
    epsom
    348
    52
    Talkingsuspension
    Hi Vinny thanks for your info,I've bought some wishbones and a subframe so I'm going to have a play about and see what i can make,I have some cortina uprights so hopefully i might ge able to make some kind of hybrid front end....knew my o level metalwork would come in handy one day
    Jan 2010
    epsom
    348
    52
    Thumbs upmazda suspension
    cheers stevie t
    Jul 2009
    bradford
    70
    i've been looking at the rx7 front suspension today,you could use crossmember,steering rack,bottom arms and uprights,the strut bolts to the upright with two bolts so it would be easy to fix a balljoint/fabricated top arm instead of using the strut,the rx7 also has alloy hubs and lower arms as standard.
    1. austin, bmc, front suspension
      Last Post: 17-05-2010, 10:10
    2. Which front suspension?
      By mdbs in forum Tech Discussion
      Last Post: 30-04-2010, 17:30
    3. Pop front suspension
      By 4.6pop in forum On Topic
      Last Post: 03-10-2009, 17:05
    4. front struts / suspension
      By cosxr2i in forum Stuff - WANTED
      Last Post: 29-08-2009, 11:38
    5. austin front suspension
      Last Post: 06-07-2009, 11:12
