Metal Garage
Likes Likes:  1
Results 1 to 10 of 13
Thread: Metal Garage
    Aug 2009
    South Cheshire
    1,263
    59
    RockabillyBilly is offline
    Metal Garage
    I have a 33ftx17ft wooden garage that, after 20+ years, has decided it doesn't want to be here anymore and wants to fall down. I want to replace it and was looking at possibly a metal garage. Not as big as the one I have now but maybe a couple of them. Anyway; the question is; Condensation. Is that a problem you folks have encountered with metal garages or sheds and if you have, how have you sorted it out?
    Thanks nicely.
    Billy.
    May 2016
    S E London
    870
    22
    timbo56 is offline
    I have a metal roof on part of my garage and it does suffer at certain times, you can treat them with an anti condensation coating and or insulate them to solve the problem.
    Official RnS Addict scottie's Avatar
    Resin City
    3,965
    1339
    scottie is offline
    yeah condensation is a big problem, if you do nothing you will regret it
    you can get anticon stuff but its just a thin layer of felt on the underside and basically soaks up and condensation
    if you need to go metal i would board and insulate between
    12,692
    mygasser is online now
    yep i'd board then damp proof membrane before adding the metal sheets if doing a whole garage. the wood helps with insulation in the winter and coolness in the summer too.
    Aug 2009
    South Cheshire
    1,263
    59
    Thanks folks.
    Nov 2011
    suffolk
    6,021
    1417
    russ6120 is offline
    Personally I wouldn’t have a metal garage. By the time you’ve bought the metal garage and lined it with a membrane and ply you could have built a timber one. For cheapness you can get corrugated felt/fibre sheets for the roof. They are very light and last well
    May 2010
    scotland
    654
    29
    stonefree is offline
    Metal and phenolic rigid foam boards, would be the way to go,guarantee absolutely NO condensation. used it many many times
    I just picked this link, it you have a rumage about their products
    https://www.insulationshop.co/roof_i...nsulation.html
    although it says pitched roof , you get walls as well
    another phenolic company is Kingspan
    You could use Mineral Wool which more than likely is cheaper, but I have a preferance for phenolic
    Aug 2009
    South Cheshire
    1,263
    59
    Thanks for the replies and input folks. A bit of an update; After much head scratching and re thinking I have managed to save the existing garage. I've braced the wooden lintels with angle iron, reinforced the sides and am waiting for delivery of new box section roofing sheets. Also, starting to clad the outside with feather edge boards. After that, I'm making a kind of a lean to but with box section roofing and feather edge cladding. For the floor I'm going to use crush and run. I won't be working in this lean to, just parking in it. Question is, would I need a damp proof membrane such as Visqueen or isn't that needed for this job? Many thanks.
    Oct 2015
    Sussex by the sea
    832
    95
    28Chevy is offline
    Always use a membrane unless its a carport.
    I once built a small lean to like you describe, but just for storage, with very limited access.
    Dug and concreted a small footing and built a 2 brick high wall up to DPC, more like a kerb really.
    Filled and whacked the floor with rubble and levelled a layer of grit sand over, but left it down the thickness of slabs.
    Laid free reclaimed slabs dry on top of Visqueen that turned over the wall under the wall studding.
    Worked a treat and never moved, dry as a bone, so much so that when I had a larger floor to raise in a refurb property I just filled it the same way and laid Visqueen, Celotex and chip board sheets on top, no wet trades needed and very fast.
    Might be able to find pics if required.
  12. Likeschaley liked this post
  13. #10
    Aug 2009
    South Cheshire
    1,263
    59
    Thanks for that. If it's pictures of sheds or garages...yes please! I think there was a thread a while back concerning that subject...I'll have to have a scratch about and see if I can find it. Back on track; i've been having another re think; if I put a damp proof membrane down, wouldn't that stop water draining away as well as damp rising? Maybe I'm over thinking things or thinking too hard...either way is not good for me to be honest.
There are currently 2 users browsing this thread. (0 members and 2 guests)
    1. garage build, garage section
      By sqweaka in forum The Garage
      Last Post: 04-05-2015, 03:54
    2. New Garage Timber, Concrete or Metal
      By john w in forum Tech Discussion
      Last Post: 21-05-2013, 19:02
    3. Replies: 2
      Last Post: 14-02-2013, 18:32
    4. metal garage type shelving for charity shop
      By sleepy in forum Stuff - WANTED
      Last Post: 25-11-2010, 20:04
    5. metal bending metal brake
      By duffbeer in forum Tech Discussion
      Last Post: 01-03-2010, 20:29
