mk 2 jag rad
Results 1 to 10 of 10
Thread: mk 2 jag rad
    bridgwater
    289
    8
    sd156 is offline
    mk 2 jag rad
    To save a few phone calls i just want a rough price on what a recore would be on a
    mark 2 jag rad. I realise every company can be different.
    See if the one i been offered is worth buying cause it needs a recore.
    23,800
    The problem with Mk2 jags is which type of core is used as this affects the shape of the top tank and what core can be fitted. If the rad is very heavy and the core looks diamond shaped as opposed to standard zig zag or straight caross that's film core and is very expensive to replace to that standard. A modern core can be made to fit but takes a bit more time in labour and can restict the overall uprate size .
    Recore stock Jag rad probably in the £100-120 range ,film core more like £160 ish.
    bridgwater
    289
    8
    sd156 is offline
    Cheers kev
    could turn out a expensive rad then
    what else will fit in 32 grill and keep a rover v8 cool.
    I used to have a taxi rad in there and although it didnt boil it always seemed to run quite hot.
    Plus i needed a seperate expansion tank which is just too much stuff to fit in my engine bay and looked untidy.
    What does a custom made rad cost?
    23,800
    Taxi rad should have been good enough , any diesel rad is always an uprate on a petrol engined version.May have been passing through the rad too quick or simply shagged out .
    Pretty sure Mk 2 Consul ( shorter) or Zephyr (longer ) fit as well, nice shaped top tanks as well.100E shouldn't be too far out though are prone to silting up so really need to be looking at a recore, round about the £100 mark for either.
    Scratch built depends on what it's to cool as the main cost is in the core spec.
    As a rough starting price around the £150 +vat mark to cool up to about 300bhp but I can always get a specific quote against a drawing or donor rad with measurements.
    bridgwater
    289
    8
    sd156 is offline
    Its only a rover v8
    Is the £150 price on me supplying a exisiting rad or do they build one for scratch.
    Also i been meaning to phone you about my brakes and decided to go with the transit servo , do you know the diameter of a transit servo?
    Cheers
    23,800
    Price is for scratch building ,like I say would have to confirm with my old firm against a drawing .
    2 different sizes of servo ,9 inch or 9.5 .
    bridgwater
    289
    8
    sd156 is offline
    I will phone you tomorrow kev and speak about servo, i wont fit one of those under my car, i ve only got about eight inches max under my seat between chassis rail and inside chassis rail that goes along the the side of my gearbox and ties into the crossmember where my hairpins for back axle connect into.(long hairpins)
    23,800
    I think a Cortina combo is 7/8ths m/c with a 8 inch servo if that helps? You can always move it further back in th chassis to where you do have room and use an extended bar from pedal to servo. Likewise it's also possible to put it sticking through the floorpan under you seat if three is a problem with it hanging down.
    Leicester
    5,697
    594
    bigyellataxi is offline
    I have got a mk2 Consul rad sitting here, it DOES need recoring, thats why I ain't (can't afford...) going to use it...
    Over to you...!!!
    Fueled by Jim and Luckies.
    bridgwater
    289
    8
    sd156 is offline
    I ll keep you in mind what you asking for it?
    See if i can get a good one first
