Mk2/3 capri leg question
Results 1 to 10 of 10
    S.E London
    5,716
    513
    vince-305 is offline
    Anyone own a mk2/3 capri, Im trying to find out the measurement between the struts (left-right) from under the bonnet for a neighbour who too much angle on one leg compared to the other (visibly noticeable) and would like to just confirm that this is the problem ............................................. thinking about it anyone know what the caster should be so i can check this for him too
    Bit'z 'N' Piece's
    west midlands
    2,819
    259
    stevie.t is offline
    do you mean castor or camber? camber is about 1degree and castor is about 3, i think i have a manual at home so i may be able to tell you more later
    S.E London
    5,716
    513
    He hit one of those high kerbed bollards but it would just be easier to explain to him that if he has 37" between inserts and he should have 39.5 (not the brightest student) then its wrong (i think that 39.5 is close) he is also on about fitting the rally type tops at a later date so i was hoping to dazzle him with my knowledge that caster of 7% would be better than what he had (once its all square that is )
    Bit'z 'N' Piece's
    Stroker Kustom Jim's Avatar
    Bath
    5,216
    2764
    Kustom Jim is offline
    Thumbs up
    Howdy,
    I asked about the distance between the top/centre of the struts yonks ago when I fitted the
    Capri clip to my ride.
    Pretty sure the answer was 1m so 39.5" sounds pretty close !?
    I started with a spirit level on the discs to get the camber/ball rolling as it were
    cheers
    KJ
    S.E London
    5,716
    513
    I think it was me Jim that answered you lol like i say its mainly just to give him the measurements to get on and do it (i dont want to get involved with it at the moment, One of those neighbours that only want you when they want something)
    Bit'z 'N' Piece's
    Banjo snapper. Hemi Bucket's Avatar
    Knocking one out.
    3,507
    998
    Hemi Bucket is offline
    95% certain it's a meter as Jim said.
    How'd the weekend go? Well, at the moment it looks like a dolphin that's been caught in a boats propeller.
    Col
    Heavy Oiler Col's Avatar
    Feb 2010
    berks
    2,504
    299
    Col is offline
    Not bent the strut has he?
    S.E London
    5,716
    513
    Col, he may have but if we had the measurement at the top we he could rule that out
    Bit'z 'N' Piece's
    23,565
    Caster and camber are low but important as in about .5 castor and 1-1.5 caster. Don't get confused by the reports of 7 degrees etc you see bandied about in tech write ups , these figures are for drag cars where straight line stability is more important than lightness when parking and tyre life etc.
    A shagged track control arm with either worn out rubber bushes or ball joint will make a huge difference to caster.
    Also if he's pushed one leg back then it will effectively reduce the caster by shortening the lower tre, check the other side as well. Also a bent anti roll bar will have the same effect .
    S.E London
    5,716
    513
    Ill certainly will get him to check it all Kev but need the top measurement first for a starting point of reference
    Bit'z 'N' Piece's
    1. mk2 consul with capri discs?
      By tony lewis in forum Tech Discussion
      Last Post: 02-09-2010, 10:31
    2. wanted Mk1 Capri, Mk1-Mk2 Escort
      By kenny james in forum Vehicles - WANTED
      Last Post: 22-03-2010, 20:27
    3. Capri struts - Oil question....
      By dustymopar in forum Tech Discussion
      Last Post: 15-11-2009, 17:07
    4. mk2 consul/zephyr/zodiac 2.8 capri engine amd box conversion
      By Coppertop in forum Stuff - FOR SALE
      Last Post: 19-10-2009, 22:10
    5. zodiac mk2
      Last Post: 30-04-2009, 19:43
