mk2 escort front end in a ford 100e
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    charnwood cruisers 55prefeect's Avatar
    Jan 2010
    loughborough, leicestershire
    179
    53
    55prefeect is offline
    Angrymk2 escort front end in a ford 100e
    Can somebody explain to me how you fit mk2 escort struts into a ford 100e.
    I have asked so many people and i am getting so many different answers.
    I was told i could retain the original 100e top mounts which i have now managed to do by getting a steel shalf machined. But i was originally told that they would be a straight forward swop that never happened.
    Then i was told that if i fitted adjustable tcas from a mk1/mk2 escort again they would fit straight in. wrong again they do fit but the camber angle is way off the wheels may aswell be laying flat. Thats at full extention on the tcas.
    Looks like the car off back to the future.
    Has anybody got any solutions as to how i can sort this out. Do i need to fit a mk1/mk2 crossmember. Do i need a escort mk2 antiroll bar.
    I do not want to cut any of my body work even in the engine bay as shes a pearler
    cheers
    55prefeect
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Try logging on to ford100e.com if you have no joy on here.
    Very helpful crowd, and all 100e are welcome, standard to full race cars
    Leicester
    5,691
    592
    bigyellataxi is offline
    When I did my mates years ago, I put a complete mk1/2 front clip in, crossmember, rack, struts etc...
    I used some escort strut top repair panels, bolted the to the struts, and poked it all in place, pie cut the turrets and welded the tops in where they fitted, then filled in the gaps.
    Also welded the x member in, but it could have been bolted in for ease of removal.
    There was some camber there, but not overly, seemed to work fine when it was up and running.
    HTH???
    *edit* the classic capri (??) ones are 'supposed' to be a 'direct' fit, but we went that route first, as you say the TCA's don't work...
    Gimme a nod if you want a 'proper' chat, as I ain't that far away...!!!
    Guy
    Fueled by Jim and Luckies.
    Official RnS Addict hellblue's Avatar
    southwest
    725
    4
    hellblue is offline
    When i did this some years back i made my own xmember but i see no reason why you shouldnt use the whole escort set up, from what i remember going by the escort rack it pulled the track in a bit (which the 100e needs) this ment the top mounts needed sorting to keep the camber, set your caster angle & all geometry with the car at its rake & ride hight you want when finished, by using the escort xmember you wont have bump steer problems & you should be able to use the escort roll bar or as i did fit compression struts if you want use the escort column & any joint you need for that you can get from rally design & anybody that tells you anything like this is simple is either a pro or they aint got a clue you will need to weld & understand how to set up the suspension
    oh & if you convert to the smaller 2.25 dia springs it will give you more room in the towers
    Kent
    422
    8
    Morecubes is offline
    22,830
    Quote Originally Posted by hellblue View Post
    Wise words !
    I've seen loads bolted into position where the caster and camber is dreadfully out . If you are moving suspension from one car to another you may need to alter the top turrets to get the matched widths as on the donor or adjustable TCAs if if needs to come in top and bottom to match.
    Same applies to swapping racks around there is far more to it than most realise if you do not want to end up with bumpsteer and /or strange handling.
    Rods 'n' Sods Junkie duffbeer's Avatar
    Jan 2010
    fife scotland
    126
    duffbeer is offline
    the strut tops i used to sort out the camber on my 100e
    Official RnS Addict yellapop's Avatar
    southampton
    906
    109
    yellapop is offline
    if you need crossmember i have one...i also have a pair of classic/capri struts !
    Leicester
    5,691
    592
    I never said it was easy...
    It reads easy...
    I'm a grown up member now ! largeeng's Avatar
    Oct 2009
    East Peckham,Kent
    83
    63
    largeeng is offline
    I did this conversion years ago on my own Pinto powered 100E. Its not too difficult but definately not a bolt in. I made my own cross member and TCA's. I wanted the car to sit low and the escort items wouldn't allow this, the ball joint on the end of TCA would be at its limit of movement. Also making my own crossmember allowed me to set the engine a bit lower in the car aswell. As youve already gathered the top mounts need relocating also.
    All in all tho its a conversion well worth doing.
    1. 100e Escort Gasser Build
      By matt100e in forum The Garage
      Last Post: 13-05-2012, 11:05
    2. Replies: 0
      Last Post: 21-05-2010, 17:52
    3. Mk2 escort rear axle and front struts
      By Andy Nineham in forum Stuff - FOR SALE
      Last Post: 10-04-2010, 19:37
    4. Ford Capri & Escort items
      By MUTANTV8 in forum Stuff - FOR SALE
      Last Post: 04-04-2010, 10:32
    5. Escort Front struts MK 1 or 2 ? not
      Last Post: 03-03-2010, 12:23
