Modifing rover v8 su carb to take 4 barrel carb
Results 1 to 10 of 10
    I'm a newbie !
    Nov 2011
    slough
    5
    rat ted is offline
    Could any one who has done this, let me know how the feeds to each cylinder inside the manifold where modded.i have managed to find diagrams for 4 different ways to set up the feeds but no info on how they performed. Photos would be a great help . Also how did it compare on the road with a off the shelf 4 barrel manifold. Thanks rat ted
    Official RnS Addict andycamaro's Avatar
    Apr 2011
    Sussex
    656
    28
    andycamaro is offline
    surely you would buy a manifold for the 4bbl carb rather than try to modify the original 2 su carb manifold.
    have seen ofenhouser? intake manifolds for 4bbl carb setups on the bay and i believe this should be the way to go.
    Official RnS Addict harris66's Avatar
    Jul 2009
    solihull
    2,385
    79
    harris66 is offline
    we used one last year on our rover v8, but we bought it ready modified, it really looked like the su mounts had literally been machined off flat, and the alloy 4 barrel mount welded on, it did look fairly restricted, but must say ran spot on with a 390 vac sec holley,
    its a cheap way to get a big carb on but if i did it again i go straight for the edelbrock manifold
    i want cubic inches! lots of em!!
    Bridgwater
    727
    37
    scooder is offline
    In my little knowledge of the ally V8, I have often herd that the stock manifold machined flat and 4bbl mount welded on as above, works really well and know of a bloke that had a modified one on his, and "up graded" to an Offy, After a month or so the Offy was sold on and the modified stock one was back on. The stocker and 4bbl pulled lots cleaner and was more punchy at low revs, the Offy was not as punchy down the bottom but no better at the top either. The Edelbrock is better than the Offy all over, and better than the modified stocker up top.
    Martin.
    watford
    1,109
    firebird68 is offline
    I have a Rover manifold machined and reworked on a 3.9 engined Stag- it works very well ,not restrictive at all.
    Feb 2010
    Selby north yorks
    1,983
    135
    rodster is offline
    Back in the 80s thats what me an me brother did with our pops, if memory serves me right we used the p6 manifold, chopped off the main top then have em machined down to a suitable hieght our were inline with the crank, from memory what you are left with is two chambers and a water jacket in the middle, the water jacket needs welding up first then get yourself a suitable lump of alloy and get it shaped drill tapped etc for your carb and weld the sucker on, square. job done.
    Oh yeh we had ro34 blowers on ours with no problems at all, had a look for some pics but cant find any suitable, oh and make sure you get a pro to do the welding as the alloy is often contaminated and not easy to weld.
    Bill
    oxon
    215
    pxr5 is offline
    Unless your engine is highly modified stick with the SU's, the SU's although simple are far better.
    Clean up the area before the bridge & flow the butter flys- good increase with CFM is possible.
    You could also use Jag 2" SU carbs, they have no chokes but that can be fixed...
    I'm a newbie !
    Nov 2011
    slough
    5
    rat ted is offline
    thanks for the reply.can you remember if it had a deviding plate in it (front to back) or was it just a large hole under the carb.
    Feb 2010
    Selby north yorks
    1,983
    135
    rodster is offline
    Quote Originally Posted by rat ted View Post
    memory aint that good im afraid
    I'm a newbie !
    Nov 2011
    slough
    5
    rat ted is offline
    nor is mine , what was the question. thanks
    1. Replies: 5
      Last Post: 26-07-2011, 19:33
    2. rover v8 su carbs with manual chokes
      By petrolhead in forum Stuff - WANTED
      Last Post: 25-03-2010, 22:25
    3. Rover V8 SU throttle linkage needed
      By klassicdave in forum Stuff - WANTED
      Last Post: 22-03-2010, 21:45
    4. Replies: 9
      Last Post: 02-02-2010, 17:39
    5. holley carb plus rover v8 bits
      By harris66 in forum Stuff - WANTED
      Last Post: 31-01-2010, 18:58
