More fuel pump - what to use
Results 1 to 6 of 6
    Rods 'n' Sods Junkie matt100e's Avatar
    Jul 2009
    Stroud
    267
    17
    matt100e is offline
    Hey guys,
    Any ideas as to which fuel pump will be best suited to a 302ci sbf in standard tune with a 600 cfm holley carb?
    Its goin in the escort gasser when I can finally get the bugger out the garage an in the workshop!! And is there an advantage to using say the facet interupter over the solid state?
    Cheers, Matt
    Official RnS Addict mikeyboy's Avatar
    San Diego.Calif USA
    2,422
    209
    mikeyboy is offline
    Re: More fuel pump - what to use
    The stock mechanical is all you need for a mild 302 with a 600 cfm Holley.
    There's no replacement for displacement.
    Jul 2009
    Stroud
    267
    17
    matt100e is offline
    Cheers Mike, Only problem is it hasnt got a stock mech pump as its a '89 efi motor but i've stripped the efi off and putting a carb on top
    London Heathrowish!
    7,724
    46
    Plumpcars is offline
    I've used both types of Facet in that sort of situation with no problems. The little solid state is surprisingly good...I had one feeding 6 Webers and it was fine when driven hard.
    Chester
    131
    blackjack is offline
    I think there's also an advantage to using an electric pump over a mechanical one in a car that's not driven every day.
    I've just replaced the mechanical one on my trike with an electric pump because I was placing unnecessary strain on the battery and starter motor using them to pump fuel into the carb after it had drained back or evaporated. Now I just wait for the pump to stop ticking and it fires right up.
    San Diego.Calif USA
    2,422
    209
    mikeyboy is offline
    Quote Originally Posted by blackjack View Post
    You can also, using a thin funnel, pour a little fuel down the vent tube of the bowl to prime it after its been sitting a while saving cranking it
    1. Fox Mustang fuel pump
      By 57peppershaker in forum Stuff - WANTED
      Last Post: 07-04-2010, 13:19
    2. Mallory 140 fuel pump
      By randrhotrodimports in forum Stuff - WANTED
      Last Post: 20-03-2010, 10:48
    3. electric fuel pump ?
      Last Post: 02-11-2009, 17:45
    4. fuel pump
      By 58 delray in forum Tech Discussion
      Last Post: 13-09-2009, 07:51
    5. Fuel pump advise please
      By 56 AUSTIN in forum On Topic
      Last Post: 07-06-2009, 19:49
