mot question
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: mot question
    Walsall
    681
    6
    Adey is offline
    mot question
    My daughter car had an advisery that the head gasket was leaking oil. the car is now out of the time to return it free for a retest.
    The garage have said that this since monday this is a fail?
    is this correct ?
    race engines.
    Rods 'n' Sods Junkie ChevyStepside's Avatar
    Dec 2012
    Clacton Essex
    125
    28
    ChevyStepside is offline
    Below are the new MOT failable items. They can fail on any oil leak if its bad enough - have been able to for a while.
    The main ****er on this list is the airbag light!! thats gonna cost people some money to fix!
    For Class 4, 5 and 7 vehicles:
    Headlamp levelling and cleaning devices when fitted for HID or LED headlamps
    Main beam ‘tell-tale’ warning
    Battery (including batteries for electric or hybrid vehicles)
    Electrical wiring and connectors
    Trailer electrical socket security and damage
    Operation of 13-pin trailer electrical sockets using an approved trailer socket tester
    Operation of the steering lock (where fitted) including a malfunction warning in respect of an electronic steering lock
    Electronic power steering malfunction indicator lamp
    Electronic parking brake control and malfunction indicator lamp
    Electronic Stability Control (ESC) components, including the switch (if fitted) and malfunction warning
    Brake fluid warning lamp illuminated or inoperative
    Tyre Pressure Monitoring Systems (TPMS)
    SRS components including airbags, seat belt pre-tensioners, seat belt load limiters and SRS malfunction warning lamp
    Engine mountings
    Speedometer
    Indirect vision devices (where they replace obligatory mirrors)
    Additional new items for Class 5 vehicles only:
    Electronic braking system warning device
    Entrance/Exit Steps and doors
    Door remote and emergency controls
    Door open warning devices
    Stairs
    Emergency exit signs, windows and ‘break glass’ hammers
    NEVER GO FULL RETARD
    Walsall
    681
    6
    Adey is offline
    cheers so basically the rules have not changed on this.the garage is having her on, as its a new rule
    race engines.
    Official RnS Addict rides's Avatar
    Jan 2010
    In dwarf land man it's a whole different world
    585
    rides is offline
    Yes they are pulling a fast one
    It's still advise
    But they can only put a red advise if they think it is really bad
    Ok
    if they do test the car and do a gas test they are saying the car is fit for test so oil leak is not that bad ??? Bec they have the right to refuse to test if a danger to vts bay or vehicle
    Only oil leak that is a fail is p.a.s leak
    Al
    My spelling is so bad spell check ant got a clue ??
    Feb 2010
    Selby north yorks
    1,983
    135
    rodster is offline
    The new rules came in on wed 20th so thats wrong for a start, engine oil leaks are not a fail unless it is deemed unsafe to carry out the mot or carry out an emissions test, find another test station it sounds like they are short of work.
    Dec 2012
    Clacton Essex
    125
    28
    May 2010
    lichfield staffs
    4,451
    407
    streetfighter is offline
    if you know EVERY SINGLE new rule, the airbag light is not going to cost much money to fix.....................
    Jul 2010
    scotland
    749
    13
    dannymac is offline
    More often than not the airbag light is often a simple fix,under the seats,you find a wire going up to the seat belt clip,modern cars have that tensioner activator doo-da thats fired off when an air bag goes off ,to tension the seatbelt,moving seats forward and back or something catching the wire sometimes unplugs or breaks that cable.Always worth a check before you go for diagnostics
    Official RnS Addict corvette's Avatar
    Dec 2010
    Nottingknifegunshire
    1,154
    64
    corvette is offline
    take it somewhere else and steam clean engine down just before you go, wont fix head gasket ,but will get a years ticket
    Official RnS Addict stu460's Avatar
    Jul 2011
    Cheshire
    1,790
    66
    stu460 is offline
    Quote Originally Posted by dannymac View Post
    If your lights on then it has to be reset with a tool (well on a BMW is does). Cleaning up the contacts etc may remove the fault but the light stays on. BMW charge £50 a pop to reset the light. The tool is $70 from Peake in the USA direct to your door.....
    1. Mot question
      Last Post: 06-12-2011, 00:51
    2. hand brake mot question
      By mr badger in forum Tech Discussion
      Last Post: 23-08-2010, 09:00
    3. Klaxton Horn and MOT Question
      By Gr8h8me in forum Chat
      Last Post: 18-10-2009, 17:33
    4. MOT question, brake pipes
      By Taff in forum Tech Discussion
      Last Post: 09-08-2009, 15:28
    5. MOT question
      By jim351 in forum On Topic
      Last Post: 17-05-2009, 10:02
