Mounting a brake pedal
Results 1 to 6 of 6
    Nov 2011
    suffolk
    6,075
    1430
    russ6120 is online now
    I’m fitting a new master cylinder and servo but want to have the master cylinder on the engine side of the bulkhead and the servo on the inside. Will the servo be strong enough to bolt the pedal straight to it?
    Russ
    12,925
    i'd like at least a 'stay' bracket pedal side of the servo up to the dash or suchlike if it was me mate.
    Nov 2011
    suffolk
    6,075
    1430
    The pedal does come with a bracket that will bolt onto the four studs on the servo. Didn’t know if this would be enough
    23,275
    You will have to adjust the inner pushrod / make spacer to allow for the thickness of the bulkhead . That thickness can translate to 3/4" extra travel plus at pedal otherwise!
    Nov 2011
    suffolk
    6,075
    1430
    I’ve got a small lathe so I can always make a new push rod
    12,925
    If you make my a for mentioned stay bracket the same thickness as the bulkhead you kill 2 birds with one stone.
