Negative to Positive earth
Results 1 to 8 of 8
    May 2010
    Dublin
    62
    8
    RatRover is offline
    I have a tachometer which is negative earth. My car is positive earth. The diagram says it "is not designed" for positive earth. Is there a way to convert from negative to positive earth? Or does anyone know where I can get a reasonable positive earth tach?
    UK
    105
    arsenic is offline
    The swap is (on a Minor at least) very simple -just flashing the dynamo and changing the battery leads. No idea how it may afect other instruments/fuel pump/heater on a rover, though (always assuming that you do have a Rover)
    Official RnS Addict farncombe pop's Avatar
    Farncombe Surrey
    4,274
    42
    farncombe pop is offline
    Quote Originally Posted by arsenic View Post
    Don't forget to swap the coil leads, will work but burns out points in no time.
    Here to help !
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    As said by Arsenic. Why not change the car to negative earth. Nothing really to do other than reversing the battery and coil leads (and the ammeter leads if you have one fitted) Any modern accessories that you might fit to the car in the future like Alternators, radios etc. will all be negative earth anyway.
    Stuart.
    My Intro
    May 2010
    Dublin
    62
    8
    RatRover is offline
    I do have a Rover. I was hoping to keep it oroginal but it might be easier to switch it over. Thanks.
    May 2010
    Dublin
    62
    8
    RatRover is offline
    So I have been reading up on how to "flash" a dynamo. Does anyone have any tips from experience on how to do this correctly? It seems pretty straight forward but it's always good to hear from someone who ohas done it before. Also, I was toying with the idea of putting in an alternator instead. Is there one that fits well on the rover 6 cylinder?
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    There's several ways to "flash" i.e. polarise or set the residual magnetism on a dynamo, they all do the same thing though. Once you've reversed your battery terminals, just momentarily connect your "new" live (positive if you're going negative earth) to the field connection (that's the small Lucar terminal if it's Lucas ) of the dynamo. Have the field connect wire which goes back to the regulator off the field connection when you do this.
    You'll see a small spark, but you won't damage anything. When you run the car the dynamo should start charging.
    If you want to change to an alternator, any of the Lucas ACR series should line up quite well with your Lucas Dynamo front mount. You'll need to do something for the rear mount as alternators are shorter than dynamos.
    Stuart.
    My Intro
    May 2010
    Dublin
    62
    8
    RatRover is offline
    Thanks for that stueee.
    1. Negative earth starter question
      Last Post: 13-12-2010, 18:18
    2. Positive/negative earth question
      Last Post: 13-04-2010, 13:22
    3. The rarest tri chevy on Earth for sale
      By Steve 5-6-7 in forum Tri Chevys, Spirit Of the Fifties and the Tuck Up Squad boys
      Last Post: 01-11-2009, 17:28
    4. Replies: 10
      Last Post: 10-08-2009, 07:18
    5. 6 volt flathead positive earth
      Last Post: 11-05-2009, 21:54
