noise coming from back end jar irs
Results 1 to 7 of 7
    Rods 'n' Sods Junkie vw2v8's Avatar
    wrexham
    395
    8
    vw2v8 is offline
    and its weeing me off,
    the noise is a knock that goes faster when i go faster been through the back end changed the rear wheel bearings both sides,both sets,replaced diff oil with correct amount,no lose bolts around the calipers,there is one thing ive noticed with a little bit of play and thats a inner uj would i get a knocking noise from this,put it on axle stands spun the back end but no noise.ive even tried it in gear running to get to a decent speed on axle sdands but no noise...could it be a dodgy bearing,ive done about 50 miles on the new bearings and help please thanks
    23,472
    Did you set the preload / endfloat on the new bearings ?
    wrexham
    395
    8
    vw2v8 is offline
    no i didnt how do i do that,or have i ruined the bearings
    23,472
    It's easy enough to do but the trouble is getting the preload shims as Jag dealers only sell them in packs of 10 of one size and they are about £5 each . I manange to work out what I needed and got hold of a local Jag reapir specialist and bought 3 different sizes at £5 a piece. I ended up linishing one down to the required size.
    I'll have a look in a minute to see if thereis anything on the 'net about how to overhaul them .
    EDIT , here ya go, first one I found
    wrexham
    395
    8
    vw2v8 is offline
    thanks for the link/info,but what is the noise have i damaged anything,i did follow another link and what they said as long as you put everything back to were they were,with new bearings it should be ok ..
    ill go and strip it down as see what i can find,i take it somthing will be broke?to cause the noise
    23,472
    Just slop in the bearing and it sliding up and down the shaft ( probably). I did a set about 8 months ago that had been in use for about 6 months and they were fine.
    Chances of it 'just ' going back together are slim, all about production tolerances. If they weren't needed they wouldn't make them would they ?
    wrexham
    395
    8
    vw2v8 is offline
    thanks very much for your help...ive now found the problem it was a round plate between the the hub and carrier...dont know what its for, some sort of cover ,it had come lose and got jamed and was catching,ive now taken it off and now there is no noise..so what is that cover for do i need to find another one or is it ok without it..again thanks for the help
    1. SBC dizzy noise
      By Keith in forum Tech Discussion
      Last Post: 21-05-2010, 22:27
    2. 10pm is coming.....
      By Torment in forum Chat
      Last Post: 21-01-2010, 20:43
    3. new tiki coming soon
      By movinghotods in forum The Garage
      Last Post: 03-11-2009, 10:36
    4. For those of you coming to LA....
      By mikeyboy in forum On Topic
      Last Post: 03-05-2009, 01:14
    5. Stand back, the Leicester crowd are coming
      By Blown 100e in forum Who are ya ??
      Last Post: 23-04-2009, 20:13
