normal running temp
Results 1 to 10 of 14
    Rods 'n' Sods Junkie supateach's Avatar
    Oct 2013
    rotherham
    182
    129
    supateach is offline
    normal running temp
    I am currently trying to get my temperature gauge to work accurately, it has the BMW sensor in the engine and the original toyota gauge, it was originally reading very high so I put a small 10 ohm resistor in series with the sensor to drop the needle down a bit and I tested it with the sensor wired up in a kettle with a thermometer in it . I set the gauge at half way at 85 degrees. however when I run the car the gauge goes up past halfway. what temp should it run at and could anything else be causing the gauge to read high when the sensor is in the engine
    Thanks
    13,425
    have you checked the actual engine temperature when it's 'up to temp'? most modern engines run way higher than 85 degrees.
    Jun 2016
    Roswell, New Mexico
    878
    NMNeil is offline
    About 200F (93C)
    Oct 2013
    rotherham
    182
    129
    thats why the gauge reads high I thought it should running about 85, how would I check the actual running temperature, once its hot I cant get the cap off to check with a thermometer
    Oct 2013
    rotherham
    182
    129
    just been reading another thread about overheating and someone suggested the correct rad cap is important, mine will be over 40years old so I assume another would be a good idea, how do i know what is right pressure for my system there is no mention of it in the manual
    Thanks
    up north
    1,987
    35kid is offline
    rad cap is only really important if water is boiling up and spilling out the top.
    up north
    1,987
    35kid is offline
    Quote Originally Posted by supateach View Post
    use a laser thermometer then you don't need to take the top off.
    13,425
    You could put some liquid in one of the dips in the inlet or cylinder head and then measure it with your thermometer once up to temperature.
    Oct 2013
    rotherham
    182
    129
    now thats clever
    13,425
    now thats clever
    or cheap, depending on your point of view. I try to work with what I have.
    1. SBC running temp question
      By boyceeeee in forum Tech Discussion
      Last Post: 07-06-2016, 05:56
    2. Normal Running temperature of a 2ltr Pinto engine
      By Curnie in forum Tech Discussion
      Last Post: 10-06-2010, 07:24
    3. Running temp Blown 350 chevy ?
      Last Post: 24-08-2009, 20:27
    4. capillory temp gauge
      Last Post: 10-07-2009, 12:24
    5. BBC running problems
      Last Post: 18-06-2009, 08:35
