Oil pressure light and gauge... a T or....?
Likes Likes:  2
Results 1 to 10 of 10
    Rods 'n' Sods Junkie [JP]'s Avatar
    Apr 2014
    Hampshire
    458
    [JP] is offline
    Hi all,
    my impala has an oil pressure gauge. it works, that's good because I like to know what the oil is doing.
    No oil light though, that's been unplugged, wire and connector is there though.
    In my C10 I wired up the oil pressure gauge and the dash oil light pressure in the same place, just next to the oil filter, using a T splitter and had both capilar gauge and oil light pressure gauge on it.
    On the Impala.. what you reckon will be best to do?
    The capillar gauge is currently connected next to the dizzy, top of the engine, and there's a connector hanging off the wiring loom in that area (which I can only assume would have been for the pressure sensor, but still have to wack 12V on it to see if it lights up on the dash) .
    I could put a T there, connect a new pressure sensor and job done. but might look a bit bulky for the small area?
    what's the views of going in separate locations?
    I was thinking about connecting the pressure sensor where it should, on the top of the engine and then connect the pressure gauge on the side of block just above the oil filter? I think that's a place that also gives you the oil pressure? the small hole, I think 1/8NPT
    May 2016
    S E London
    979
    22
    timbo56 is offline
    I used a T piece from the same place next to the distributor, It's Not too bulky. I also change the plastic capillary pipe to a stainless steel covered -3 PTFE pipe
    Apr 2014
    Hampshire
    458
    [JP] is offline
    mhh.... I seen some of the oil pressure switches and they look (at least on the photos) kinda long, although there was a couple of shorter ones but then I was worried would be too much on top of the block.
    I might go for the top then and just buy a T....
    Need to check the gauges I have, have some new Moon gauges that been kicking about for a year or so, never fitted. and the ones in the car the water temp sensor is busted, so thought replacing it all.
    another job for the list, check threads on the moon oil gauge, the pressure sensor, the block and then order a T to match.
    May 2016
    S E London
    979
    22
    timbo56 is offline
    I can't upload pics or I'd put one up of mine
    9,348
    1777
    blackpopracing is offline
    I used a T peice as well. Put the oil light sender on the side of the T and the pressure gauge in the top as its a bit close to the dizzy otherwise.
    Timbo, can you supply more details of your plastic tube replacement?
    I'm a grown up member now ! Mals32b's Avatar
    Sep 2017
    Whitworth
    54
    Mals32b is offline
    I found a Y piece gives more room on a SBC than the T piece. This issue is finding a sensible priced 1/8 npt fitting here. In the USA they are very cheap
    Mal
    9,348
    1777
    A kind person on here donated one to me, but I believe it was a Harley Davidson one.
    Apr 2014
    Hampshire
    458
    [JP] is offline
    Well, I have ordered it now, got the T piece and the oil sensor unit, thursday looks like a dry day so booked that off work to get some more jobs ticked off the car before reg comes through.
    hope I have time to ditch the old gauges and fit new ones
    May 2016
    S E London
    979
    22
    timbo56 is offline
    I used a Tee with the light switch to the side and the pipe for the gauge straight out the top. The pipe I used is braided -3 Moquip https://www.thinkauto.com/acatalog/O...ttings_94.html which I had left over from making brake lines on my race car. More here on page 43 Aeroquip hose and fittings, same stuff better quality https://www.thinkauto.com/acatalog/T...uto_Cat_V3.pdf It originally had the plastic pipe JP shows in his photo but it was leaking onto the heater switch which caused a bit of smoke when I put the blower on.
  12. Likes blackpopracing liked this post
  13. #10
    Apr 2014
    Hampshire
    458
    [JP] is offline
    Well.. still waiting for the light switch sensor to turn up, but meanwhile I noticed the T piece was quite fat and rubbing on the engine block, so spun that quickly on the lathe to trim it down.
    Now I can actually feel how much its tightning without having the resistance of the block when goes past the flats.
  14. Likes timbo56 liked this post
