Oil pressure sender
Results 1 to 10 of 11
    I'm a newbie !
    Sep 2018
    Houghton Le Spring
    11
    Archer is offline
    Oil pressure sender
    Good evening gentlemen,
    I have a 51 F1 with a 350 sbc, it was built before I bought it, and im having trouble with the oil pressure gauge.
    When I first got the truck, the oil pressure didn't seem to read anything, I put it down to a faulty switch, as the engine ran fine, no knocks or rattles etc.
    Then the switch started leaking, so I thought I would replace it with something that actually moved the needle.
    So I bought a new switch from demon Tweaks, after first checking the gauge itself was working, shorting the wire to earth had the needle moving.
    I bought this one https://www.demon-tweeks.com/uk/sear...y/q/lmatim097/ but still have no movement on the needle.
    I have measured the pressure using a stand alone pressure tester and its fine. The truck was converted to 12v before I bought it , im not sure what kit/loom/trickery was used.
    any advice would be so gratefully appreciated.#
    cheers.
    Dave
    Oct 2009
    grays essex
    380
    16
    sebspeed is offline
    does the sender have the correct ohm's range to suit the gauge?
    Stroker Kustom Jim's Avatar
    Bath
    5,037
    2707
    Kustom Jim is offline
    I fitted electric sender gauges last year and discovered that they needs very stable voltage. I fitted a 10 volt!? stabiliser (I think) off eBay to the power feed for them and bingo they all worked including oil gauge, just takes a while for needle to wind up
    For example on the official Smiths gauge website it has this requirement in the small print!!!
    https://www.merlinmotorsport.co.uk/p...liser-cb-vstab
    Carroll Shelby
    Jul 2014
    New Zealand
    196
    5
    mylesdw is offline
    Sounds more like a mismatch between the sender and the gauge than a voltage regulation issue. You would still expect it to work without a regulator, just rather inaccurately.
    Nov 2009
    Ol'fordshire
    2,944
    88
    JackGriffin is online now
    Is it earthed through the threads properly? Unlikely to be the problem, but a smallblock Chevy would have an 1/8" NPT thread I think, so if someone used gobs of PTFE tape or sealant that could affect it?
    Screw EU
    I'm a newbie !
    Sep 2018
    Houghton Le Spring
    11
    Archer is offline
    Quote Originally Posted by JackGriffin View Post
    It has a right angle adapter on the block form the sender to screw in to, I took the whole thing off and cleaned everything so don't think its an earth problem. I may have to investigate further, im not sure what wiring kit the truck has, but the gauges look to new to be original.
    I'm a newbie !
    Sep 2018
    Houghton Le Spring
    11
    Archer is offline
    Quote Originally Posted by Kustom Jim View Post
    I have a voltage stabiliser somewhere, wonder if its worth trying, My fuel gauge doesn't really work as well, so worth a try . Thanks everyone.
    Jul 2009
    three holes, wisbech, cambs
    5,073
    963
    352 kum is offline
    throw it away and use a capillary type setup
    I'm a newbie !
    Sep 2018
    Houghton Le Spring
    11
    Archer is offline
    Quote Originally Posted by 352 kum View Post
    The guage in the original cluster isn't capillary tho, as it happens, I did find an old smiths pressure guage yesterday amongst my late dads stuf. . . . . hmmmmm
    Forum Sponsor RAYS CLASSICS.COM's Avatar
    Apr 2010
    san carlos california
    3,235
    6667
    RAYS CLASSICS.COM is offline
    hook up a capillary tube gauge & see if it registers if it does you're good to go if it does,nt you have a problem .
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. Mark
