Open drive Pop?
Results 1 to 3 of 3
Thread: Open drive Pop?
    Florida
    41
    Flat Ernie is offline
    Open drive Pop?
    OK - an odd request.
    For reasons known only to my daft brain, I wish to convert a Pop rear axle to open drive like folks do with Model A and V8 rear banjo axles.
    I don't want to use a 100E back axle because (here comes the daft bit), I wish to retain the mechanical brakes.
    BTW, this is going in a Model-Y...don't ask.
    So, has anyone ever successfully converted a pop back axle to open drive or, option B, adapted Pop or Y mechanical brakes to a 100E back axle?
    23,343
    Re: Open drive Pop?
    Don't know the answer but I would find out the torque limitations of that axle before going too far considering your choice of engine Possible need something from a heavier axle ie E83W maybe ?
    Florida
    41
    Re: Open drive Pop?
    Yes, I have looked into two short-side E83W axles mated to a V8 banjo, but a couple problems present themselves - first, sourcing two short-side housings! Second, that's not just a cut & shut deal - there's quite a bit of machining involved.
    One of the objectives is to obtain a better rear ratio for the Y. Stock is 5.5 - same as the pop. The 100E is better than that (not sure on ratio off top of my head), but I know there are "high speed" crownwheel/pinion sets for the pop at 4.7 and 4.3. The open drive is convenience more than anything...that and the possibility of using 100E trans...
    V860 won't happen soon - interim engine will be 100E most likely, but want to get the rpm down.
    1. Garys Shack open day '81?
      By Hemi Bucket in forum History Archive
      Last Post: 03-05-2016, 15:41
    2. Brookspeed International open day..
      By jim351 in forum What, Where, When ?
      Last Post: 14-04-2010, 07:58
    3. ASL open day
      By THE VIKING in forum Chat
      Last Post: 09-06-2009, 16:46
    4. Open to closed drive conversion
      By Russ Gaylord Fontana in forum Tech Discussion
      Last Post: 10-05-2009, 09:58
    5. Open drive kit and Pete & Jake Ladder Bar Kit
      Last Post: 22-04-2009, 09:07
