Overheating advice please
Results 1 to 4 of 4
    I'm a newbie !
    Aug 2014
    Essex UK
    9
    jcundall is offline
    Starts up ok when cold and runs fine, when it gets hot it starts to miss and then if turned off won't restart until it's cooled down probably an hour later.
    So far tried a new fuel pump and carborettor to no avail
    It's an old ford consul
    Any ideas?
    Nov 2011
    suffolk
    6,150
    1453
    russ6120 is offline
    Coil? They can break down when hot
    Lower Kingswood, Surrey
    3,426
    185
    Mad Mark is offline
    Quote Originally Posted by russ6120 View Post
    Especially if they should have a ballast resistor, but don't have it fitted!
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Coil is one possibility, carry a spare and when it does it swap wires to verify.
    Is there a thermal sheild between inlet manifold and exhaust manifold. May be fuel vapourising in float bowl.
    Try an electric pump in place of standard.
    1. welding advice please
      Last Post: 22-09-2009, 10:16
    2. welding advice please
      By sqweaka in forum Chat
      Last Post: 22-09-2009, 09:08
    3. big block advice please !
      By philhrc in forum On Topic
      Last Post: 16-09-2009, 07:40
    4. Advice please from those of you who use couriers
      By Hot Rod Widow in forum Chat
      Last Post: 06-07-2009, 23:04
    5. kapri, advice please!
      By banished racing in forum Chat
      Last Post: 22-05-2009, 12:18
